Who has ET Streets on Late Model Camaro Rims
Old 03-20-2008, 01:24 PM
camaro98z28's Avatar
Default Who has ET Streets on Late Model Camaro Rims
I have tubes and tires to put on my Salad Shooter wheels and I've see them done. I was wondering who has that setup and how does it work for you. Also should I run a different rim? What size or brand "Cheap"?
Old 03-20-2008, 02:35 PM
wyldcdn's Avatar
I had em on mine
I didn't enjoy them. Less sidewall , walked around too muchat top end for my liking to keep em. I was running them at 20lbs. They were 28x10.5x 16. I did not gain anything in times, or MPH. So went back to drag radials and a 26 height
Attached Thumbnails Who has ET Streets on Late Model Camaro Rims-000_1264.jpg   Who has ET Streets on Late Model Camaro Rims-000_1274.jpg   Who has ET Streets on Late Model Camaro Rims-000_1262.jpg   Who has ET Streets on Late Model Camaro Rims-000_1275.jpg
Old 03-20-2008, 02:45 PM
Thats the size I have. Whats your 60 ft time and trac times?
Old 03-20-2008, 02:57 PM
ssfast99's Avatar
yah, i have 27 10.5 16 and they are interesting on the street, unless your loading your trans to 4500 or dumping the clutch at 5000 with a lot of power, the radials are better.
Old 03-20-2008, 10:23 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I had 26x10.5x16s mounted on the stock snowflakes on my old 02 Z28
Old 03-21-2008, 09:10 AM
The problem I think Im going to have is finding a place that will put the tube in also. I noticed that the tubes valve stem doesn't go through the hole.. I think I will have to drill it out a little bit.
Old 03-21-2008, 11:45 PM
JGKadell's Avatar
I have run a couple pairs of et streets without tubes. The slowly leak air when stored, but not other problems so far. I am running 26/10.5/16's right now.
Old 03-22-2008, 01:22 AM
sixvi6-camaro's Avatar
you don't need the tube. many people don't even run tubes in full on slicks. If you do run tubes though you will have to run rim screws. If you don't the tire till rotate on the rim and tear the valve stem out of the tube. I have run a couple sets of ET streets on stock 16" rims and have never used a tube.
Old 03-22-2008, 11:58 AM
ssfast99's Avatar
no tubes here
Old 03-22-2008, 01:12 PM
99FBODY's Avatar
im running the same setup. yes they do leak when stored but i have had no other problems with them.
Old 03-22-2008, 02:22 PM
BOLO's Avatar
What about a full slick ET Drags. Can your run those w/out tubes? How low of psi can you go w/out getting into trouble? Thinking about going to full slicks.
Old 03-22-2008, 07:59 PM
Yes you can run full on slicks with no tubes. They will tend to be less stable at speed though. I've personally run 16 psi in Mt ET drags with no problems but that was only a mid 11 sec car. The only problem you may have is they will not hold air as well. Also if the tire turns on the rim you will have to run screws and at times screwed rims end up leaking air easily so then tubes would be needed. Check in drag racing tech section or post up in there for the best response.
Old 03-22-2008, 08:56 PM
GasTiresandOil's Avatar
Are these what the O.P. is talking about? 97ish-02 16x8 Camaro Rims
I have in the past ran the salad shooters with an ET Street, but could not tube it for the valve steam is in a difficult place to round out and then get the 'nut' flush on the rim.
Old 03-22-2008, 09:18 PM
99zman's Avatar
im going to have 27x10.5's on my stockers in the summer.
99zman's Avatar
what size tires are those?
Old 03-22-2008, 09:26 PM
Mike454SS's Avatar
Who's the retard that put the screws into that rim? At LEAST lay them out evenly around the rim.
Old 03-22-2008, 10:13 PM
SickboyT/A's Avatar
Originally Posted by wyldcdn
I had em on mine
20lbs? go down to 12-14, even without a tube it'll be fine
Quick Reply: Who has ET Streets on Late Model Camaro Rims
