Best cam for my Lt1
Best cam for my Lt1
I have a 96 A4 T/A right now it has a Lt4 top end kit,heads,cam,intake.I want more power what cam will make more power? I also have a rebuilt stock bottom end.
Do you have the LT4 HC? It all depends on what you wont it to do and how many rpm's you fill comfortable spinning it to. And if you have to pass a sniffer. Try the sitcky at the top " Stock head/cam swap"
Is the costume grind the best way to go? im spinning the motor to 6200 right now and pushing 336 rwhp, but want more power...the most power i can get out of a L t1. What is the cam with the most power out of an Lt1 A4?
I have an LE1 cam for sale out of my old motor. Here is what it sounded like and here is the dyno sheet with the cam.
Click here to see Video
Thing is the LT4 heads as cast suck compared to ported LT1 heads, so even throwing a cam at it it is still not going to make great power.
Had you done some research and spent LESS on good ported LT1 heads and complimentary cam you could have nearly 100hp more.
https://ls1tech.com/forums/lt1-lt4-modifications/836947-ai200-cc-heads-cam-stock-bottom-end-dyno-s-429rwhp.html
The smoke turned out to be the untouched intake not sealing right and sucking oil from the lifter valley.
Guys will tell you the LT4s are better yet ported but I just don't see it in the REAL WORLD, in bench racing land though everyone believes they are great.
Ported heads that flow under 260 cfm and I'm selling the cam because I put a stock motor back in the car and sold the old motor to fund my BBC project. Check out the Drag Racing forum and you'll see my new project.
