SPEC Clutches
Old 03-24-2008, 10:46 PM
Blu2000ss's Avatar
Default SPEC Clutches
I need to order a clutch for my car ASAP, I was going to the order the spec 3 and billet steel flywheel and I decided to do a little more research. I've looked at every page and searched, it seem like there is mixed feelings on SPEC. You guys either love 'em or hate 'em. I even read on here it's hit or miss with these clutches, I don't understand that. Should I even waste my time? I'll be about 400 at the motor. I'm really banging my head on what clutch to get
Old 03-24-2008, 10:48 PM
CaMaRo67RS355's Avatar
im getting the spec 3+ with billet flywheel too its just like every clutch some people love them some people hate them. alot of ppl have been telling me go texatrlia but they are a bit pricy plus ive heard several texatralia guys say they plan on switching back to there spec clutch.
Old 03-24-2008, 11:01 PM
BarneyMobile's Avatar
same here, Im going from and LS7 to a spec 3+ with an aluminum flywheel.
Old 03-24-2008, 11:12 PM
zach_ws6's Avatar
i've got a spec 3 that i daily drive. it has some clutch chatter, but not too bad. grabs hard
Old 03-24-2008, 11:20 PM
SScam68's Avatar
I love mine
Old 03-24-2008, 11:24 PM
The Manalishi's Avatar
This thread will likely show a mix of people that either love them or hate them just like you have all ready found. I fall in the latter category I've had a couple of them and I won't buy them anymore.
Old 03-25-2008, 12:15 AM
Y2K SS's Avatar
1st SPEC sucked......SPEC 3 11k, then went to Ram Powergrip and that blew up at 10k. Went with Textralia and broke the bank but that one felt good and lasted the longest, almost 2 years. Heard good things about the SPEC 3+ so I'm throwing that in tomorrow. We shall see.
Old 03-25-2008, 12:20 AM
Let us kno how you make out with the spec 3+. I just bought that clutch.
Old 03-25-2008, 07:36 AM
brad8266's Avatar
The 3+ is a nice clutch and lasts a long time as long as you install it right and know how to drive without slipping the **** out of a clutch. Thats the trick with high HP clutches, you cant slip them much.
I like my 3+, it holds power well, is fairly inexpensive, and drives pretty good.
Old 03-25-2008, 07:40 AM
95 Z28's Avatar
What broke on your RAM?
Old 03-25-2008, 07:51 AM
blue98Z's Avatar
Spec 3 here. Love it so far. 1200 miles and 8 track passes. Still holding up good. I know this ain't alot, but that's all I can say for now. It's a bitch while during the break in, but once it's broken in it's really nice. Good solid engagement.
Old 03-25-2008, 08:35 AM
TurdsOfMayhem's Avatar
I had MTI here in Houston put a Spec3 with Billet Aluminum flywheel in my '02 Formula. I instantly hated it. The chatter was so excessive, it shook the entire car, only time it didn't is if you revved it up real hi so the clutch would just bite.
MTI had told me it was normal, and WOULD decrease as miles were obtained on it. It actually got worse, so I called SPEC, they said with the correct 'shimming' it should not chatter at all, or be extremely minimal. Naturally MTI said they shimmed it, when I don't think it was, or even if you can...? lol
Needless to say, I bought a Z06 Clutch shortly after, and love it.
Old 03-25-2008, 11:28 AM
maedgo's Avatar
Spec 3 with stock flywheel, 4k on it and I love it. Grabs great.
Old 03-25-2008, 11:31 AM
Bad Blue WS6's Avatar
Spec 3 here as well,,,i believe its rated for over 600 HP which is a **** load more than i will ever throw at it. I do have some chatter, puck design, so its a gimme,,hooks like a champ. When it goes someday, i will probably go with a 3+
Old 03-25-2008, 11:59 AM
They have to be shimmed. The shim comes with the clutch, at least it did with the two that I had.
Old 03-25-2008, 12:02 PM
LS1TECH Sponsor
badpewter-z's Avatar
had a spec 3x at 445rwhp and got 30k and 100's of passes out of it. loved that clutch. little chatter and dont slip it mcuh and your golden . installed a few 3+'s and all of them have been great as weel. key is break in and limitied slip driving . just like ANY race clutch they hate heat
its actully going in my buddys car when his current clutch goes. i'd still have it if i never swaped the motor
Old 03-25-2008, 12:15 PM
1BadZ95's Avatar
I have a 3+ with close to 2k miles now. Some chatter if you try to slip it. especially in reverse but nothing that I cant deal with. Grabs good, just waiting to see how long she last. Very easy pedal. I'm putting about 410hp to the wheels using 295/45/17 M/T radials.
Old 03-25-2008, 03:48 PM
X.Modesto's Avatar
Those are 28 inches tall right? or around there huh? Do you have any pics? I am running 325/50/15 with a spec 3. I bought the car used and the clutch went out in about 900 miles previous miles unknown but it drove really well before it went out. Gonna order a Spec 3+ today since they say it lasts longer.
Old 03-25-2008, 03:54 PM
X.Modesto's Avatar
Found your threads, thanks for the pics your car looks badass !!!
Old 03-25-2008, 04:33 PM
Y2K SS's Avatar
The springs just blew right the hell out of it. I was pissed. I only did like 4 passes with it too. The part that really upset me was that when I called them, the guy who aswered the phone was like "bummer" and that was it. I think the clutch was like 9 months old. A few guys have had the same problem with the Powergrip.
Quick Reply: SPEC Clutches
