408 With T88 Rearmount Complete
Old 03-29-2008, 12:17 PM
vandal0-0's Avatar
Default 408 With T88 Rearmount Complete
Here are a couple pics if anyone is interested.The pics are kind of blurry,I cant figure out why.
Attached Thumbnails 408 With T88 Rearmount Complete-dscn0159.jpg   408 With T88 Rearmount Complete-dscn0162.jpg   408 With T88 Rearmount Complete-dscn0163.jpg   408 With T88 Rearmount Complete-dscn0165.jpg   408 With T88 Rearmount Complete-dscn0160.jpg
Old 03-29-2008, 12:37 PM
RooRnZ28's Avatar
install looks clean dude..... are you lowered at all?
Old 03-29-2008, 12:47 PM
vandal0-0's Avatar
Thanks for the compliment.The car is still stock height.I ended up with about 5" of clearance on the turbo.
Old 03-29-2008, 12:56 PM
grifter757's Avatar
Wow that is nice. Gives hope to my rear mount till I fininsh my custom TT which will take forever.
Hennytime's Avatar
looks great, charge piping looks small though?
Old 03-29-2008, 01:24 PM
vandal0-0's Avatar
Thanks for all the responce I appreciate it.I agree the chargepipe is the stock pipe from my STS kit.I hope it will work or I guess I will be doing some more upgrades.
Thanks
Brad
Old 03-29-2008, 04:16 PM
Dbluegoat's Avatar
looks nice and clean
Old 03-29-2008, 05:17 PM
99Z28LS1's Avatar
i dont think that the stock charge pipe will flow enough to satisfy you bro. im still in the process of a 408 and we were trying to think of a way around the charge pipe issue
Old 03-29-2008, 05:28 PM
sworaz's Avatar
Clean install. Have you got it dyno'd yet?
Old 03-29-2008, 07:59 PM
vandal0-0's Avatar
I thought I read somewere that if the chargepipe was to large it lost its velocity before it reached the motor.What are you other large rearmount turbo guys useing for chargepipe.Hopefully Zombie or Longrange4u will chime in.
Thanks,I havent been to the dyno hopefully sometime nextweek.
Thanks
Brad
Old 03-30-2008, 06:28 PM
Super Slow SS's Avatar
where did you put the MAF (if you are still using it?) and how are you supporting the weight of the turbo back there I am trying to find a way to hold mine up and keep it level so it doesn't smoke like so many have.
Old 03-30-2008, 06:39 PM
vandal0-0's Avatar
The MAF is still in the same place as before with the STS kit,after the intercooler.If you look in the pics you can see an exhaust clamp.The clamp is connected to a universal exhaust hanger that is bolted to the bottom of the car.
Old 03-30-2008, 09:20 PM
im sorry I have never had an STS kit and I am doing mine from scratch so I dont really know where that is .. but it looks like I will have to have some kind of extension for the wire cus I cant see it in the pic. So you just have one "C" type bracket bolted to the car then the exhaust clam holding onto that?
Old 03-30-2008, 09:51 PM
vandal0-0's Avatar
I was assuming you was running a STS kit my bad.You can put your MAF up top like it is know.On the STS it comes with wire extensions and the MAF is on the driverside wright in front of the alternator.On the mounting of the turbo I used the one clamp and the stock exhaust hangers like you stated.I also bought a different intermedent pipe that was two piece.That gives you a little bit of adjustment to raise the turbo up a little higher.I can get you pics tommorrow if you like of the MAF and the hanger on the turbo.
lol
Brad
Old 03-31-2008, 02:59 PM
Trans Am WS6 420's Avatar
Loks like it came out great What type of numbers are you looking for with this setup?
Old 03-31-2008, 03:13 PM
WhosNXT's Avatar
Clean install. I hope everything goes well and you don't have the issues some of the sts users have had. Good luck bro!
Old 03-31-2008, 05:07 PM
vandal0-0's Avatar
Hopefully everything will be fine.I have been running the STS kit for about 3yrs so I have the usual bugs worked out.
Thanks
Brad
Old 03-31-2008, 05:46 PM
WhosNXT's Avatar
Oh, your thread title confused me. I thought you just completed it. Good to hear all is ok!
Old 03-31-2008, 05:53 PM
vandal0-0's Avatar
I just finished this set-up.Did have stock motor with STS base kit.Then I went to the 408 with a bigger turbo,then went to the 88 for hopefully the last set-up but we'll see.
Thanks
Brad
Old 03-31-2008, 07:23 PM
venom ws7's Avatar
Great setup man I love it what H/C Are you running?? rear?? trans??
Quick Reply: 408 With T88 Rearmount Complete
