90mm maf?
Old 03-30-2008, 10:24 PM
blackbyrd's Avatar
Default 90mm maf?
who makes one?? i need one for my holly 90mm tb
Old 03-30-2008, 11:30 PM
405HP_Z06's Avatar
Here's a very nice 103mm:
http://www.powrmax.com/PowrMAF%20100.html
Old 03-31-2008, 09:57 AM
blackbyrd's Avatar
little overkill
Old 03-31-2008, 01:55 PM
ls1leadfoot's Avatar
wow is all i have to say
Old 03-31-2008, 01:57 PM
TVWilkes's Avatar
TSP has a 100mm maf.
Old 03-31-2008, 02:03 PM
deuce_454's Avatar
the least restrictive MAF is no MAF.. why not tune it for speed/density?
Old 03-31-2008, 02:47 PM
405HP_Z06's Avatar
Originally Posted by blackbyrd
little overkill
Why do you say that? Did you look at the price? Compare this to a typical stock Delphi 85mm....
Old 03-31-2008, 03:00 PM
massls1guy's Avatar
Is there a downside to running a MAF that's too big? Will it read poorly at low RPM?
Sorry if the question is off topic from the OP, just curious.
Old 03-31-2008, 04:43 PM
1999 SS's Avatar
does anyone have any experience using this maf?
does any tuning need to be done in order to use it?
i think that is a pretty good price considering they probabably dont mass produce them by the tens of thousands.
Old 03-31-2008, 04:45 PM
blackbyrd's Avatar
cause the tuner screwed it up i was gonna run sd but now i need a maf to break the car in and getting running and im probably going to use a different tuner now.
Old 03-31-2008, 04:48 PM
1999 SS's Avatar
what was the original application for such a big maf (100mm-105mm), why do it need to get the 6 pin adapter to make it work on my ls1?
Old 03-31-2008, 06:59 PM
blackbyrd's Avatar
the stand alone harness for the engine has a 5 pin plug on it
Old 04-01-2008, 01:26 PM
1999 SS's Avatar
what i mean is; since the big maf has a different plug pin arangment, what was it origanally intended for (what kinda of motor).
Old 04-01-2008, 04:25 PM
See5's Avatar
2008 Ls3/7
Old 04-02-2008, 10:04 AM
1999 SS's Avatar
wow i didnt know they used such a big maf.
is there potential for performance increase using this maf?
is there a need for any tuning to use this maf?
Old 04-02-2008, 10:46 AM
Deeavi's Avatar
We are getting ready to test one!
Old 04-02-2008, 11:04 AM
405HP_Z06's Avatar
From the factory they don't. In the '06 - '08 Corvette's they locate the MAF sensor in the air bridge, eliminating the need for a separate MAF housing. Halltech designed a custom housing, the one that Bruce sells here, to accomodate the Hitachi sensor. A new MAF table is required in the tune, but Bruce provides tables to start with. You will need someone to flash the PCM with the new MAF table.
If you do some searches, you will find that people are seeing impressive gains when using a large MAF meter.
Old 04-02-2008, 11:42 AM
00bluews6's Avatar
just go with the 85mm maf off a 6.0 its the same as a z06
Old 04-02-2008, 08:26 PM
See5's Avatar
The 6.0 85mm is the same as 01-04 Z06 which is the same as most 01-05 LS MAFs which is all different than the 06-08 and different than the 100mm PowrMAF. The new sensor is made for GM by Hitachi and is light years from the open wire early style. While your PCM may not be able to use the full range, it is ~4x the previous and far less restrictive.
