EBAY Front mount guys in here ...
Old 04-03-2008, 04:29 PM
Super Slow SS's Avatar
Question EBAY Front mount guys in here ...
I have been searching and looking at pictures but I cant find any good ones of how the intercooler piping is ran. I am doing a custom rear mount. All I see is that STS runs the pipe across the front and coming up on the passenger side then right back across the bottom under the pullies then somehow up to the intake? Does anyone have any other pics or better shots of how this is done .. also where can I get he needed MAF and IAT wire extentions if I need to move them.
Old 04-03-2008, 05:41 PM
vandal0-0's Avatar
Here is a couple pics.Not sure if they will help.One picture of were the iat sensor is.The pipe going to the intercooler on the driverside.Comes out on the passengerside,crosses over to the driverside and turns up towards the top of the motor.If you need a different pic let me know.
Old 04-03-2008, 05:48 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
EPP sells those extensions you are wanting. But one question tho- if you are making your own piping, why not just position the MAF and IAT sensors where you won't need any extensions?
Old 04-03-2008, 05:51 PM
NVR KNO's Avatar
I bought an EBAY front mount and it works great.
Wait.... Mines for my turboed skittle. Nevermind.
Old 04-03-2008, 08:36 PM
Is this an STS kit add the FM?
I thought about that too but I need a straight section of pipe before the maf thats about 10" long .. says my tuner. So it was looking like I will need to extend it .. like STS does ..
Old 04-04-2008, 09:47 AM
deadmanTA's Avatar
You could always move the battery to the trunk and bring the piping up through the pass. side.
Old 04-04-2008, 02:14 PM
vandal0-0's Avatar
Yes its a STS kit with the TRT intercooler.
Old 04-04-2008, 02:43 PM
Now that im looking at everyones pics .. did everyone cut the front bumper support to fit the FMIC? I made brackets off of the front of mine .. looks like there is plenty of room where the styrofom (sp?) was at. Pics would be nice for that too .. P.S thanks for the help
Old 04-04-2008, 05:35 PM
deadmanTA's Avatar
I just notched the back of the support in the shape of the IC and let the IC hang out the back, then put the styrofoam back on.
Old 04-06-2008, 10:11 AM
Here are some pics of how I have it now.. Please provide some feedback, im starting to think this will be sticking out to far to get the bumper to clear the pipes coming off the pass. side.
Old 04-06-2008, 10:34 AM
DuronClocker's Avatar
I pulled the big bumper support/brace and mounted the intercooler on that gray piece of plastic that the top of the bumper cover sits on. That's probably where I'm going to keep it, I just need to add a brace under the IC to mount to where the bumper support used to be. I'm going to try to use some of the foam again to keep the bumper cover from sagging and such, but we'll see how it goes once I get the piping finalized and the bumper cover back on. As it is right now, the IC is EXACTLY where I want it, and my piping will line up about perfect...and it will all tuck behind the bumper cover perfectly.
Old 04-06-2008, 10:40 AM
I wonder if everyone is mounting it behind the bumper support? Seems like it will block alot of the intercooler from getting air, and are you cutting out your bumper or doing that to leave it hidden?
Old 04-06-2008, 10:56 AM
deadmanTA's Avatar
I wish I had a pic of it with the bumper off, but I don't. Where you have the brakets bolted to the brace is about where my holes are except my IC is basically sitting inside the cross brace. It only blocks a couple inches at the top of the IC and I notched the styrofoam so it didn't block airflow. I was afraid w/o the styrofoam that the bumper would eventually get ripples and waves in it when summer and 100+ temp days started rolling around.
There's another resent IC thead where I have a finished pic. If you look closely you can see the IC, but I put alum mesh over the holes to keep trash and small animals off the intercooler. Looks like it'll get good airflow.
Old 04-06-2008, 10:58 AM
deadmanTA's Avatar
Looking at your 1st pic again I remember I notched the front of the brace up to the bottom of that rib also.
Old 04-06-2008, 11:07 AM
so you took your washer sprayer tank out and out it there? Do you have any pics .. the piping or anything? seems like it will be a hard turn to make from the intercooler to the intake that far back. Thanks for the help though.
Old 04-06-2008, 11:24 AM
deadmanTA's Avatar
Nope washer tank is still there. Let me see what I can do about some pics.
Old 04-06-2008, 11:44 AM
Thanks .. im a little confused ..
Old 04-06-2008, 12:00 PM
deadmanTA's Avatar
Batteries are dead on my camera.
I have the 3" IC. It sets only 1/2 inch infront of the washer tank. The pipping is alittle cramped, but none of the turns are over 90 degrees. The turbo is infront of the crank pulley so the charge pipe goes straight over to the pass side and then turns up and forward, then back down aliitle and into the IC. Comes out on the other side about 6" makes about a 90 at angle upwards and goes into the engine bay where the fuse panels are thes another 90 just before it comes throught there. Then I just brought it up level with the TB, I have a 4" to 3" reducer on a 45 and it runnes over to that last 90 at the fuse panels. I now it's might be hard to picture all of this.
As far as the crossbrass is concerned my IC is inside of it. I notched the enginebay side sraight across the top and the IC sticks out past it about 3/4". I hope I didn't get to confusing with all this.
Sorry for the big pics.
Old 04-06-2008, 12:01 PM
Here's what it is going to look like afterwards..except I'm having the wire mesh painted black to match the cut-up grill. It'll look more stock, plus it'll make the intercooler "pop" out
Pics below courtesy of CountryBoy hope he doesn't mind me whoring them out
Quick Reply: EBAY Front mount guys in here ...
