*******HELP - need ARP bolt torque specs. - head studs, and flywheel bolts!*******
got my short block back today, and the machine shop tossed my paperwork w/ the torque specs for my ARP head studs, and flywheel bolts. anyone have this info?
Re: *******HELP - need ARP bolt torque specs. - head studs, and flywheel bolts!*******
Head bolt specs are on www.ls1howto.com under the head swap write-up. Not sure where to find the flywheel specs. Good luck. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
im pretty sure flywheel bolts are 75 ft lbs
studs should be torqued to whatever value the machine shop used on the torque plate when doing final cylinder hone... usually between 65-75 ft lbs...
with studs you need to torque all the studs then break all loose in reverse pattern twice before final torquing which should be done in 2 or 3 passes
The torque for flexplate/flywheel ARP bolts are as follows
60 ft/lbs using ARP Moly Lube
75 ft/lbs using 30 Grade oil
