Power window motor issues
When I roll my driver's side window down, it looks like the window skips, almost like there's something caught on the track or the gear. When I roll my window up, it gets stuck about 1/2 way to 3/4 of the way up. So I take off the door panel and check behind everything and make sure no wires are in the way and then try again, and the same thing happens. This is odd because I just replaced BOTH power window motors in 2006, and they run strong. Does anyone know what could cause the window to stick like that?
Last edited by camaro_five0; 04-10-2008 at 11:19 AM. Reason: Forgot to mention "driver's side"
I posted this in another thread. Have a look and see if it helps.
I had problems with the regulator rollers in the tracks binding, that was causing mine to skip, hang and burn up motors...
https://ls1tech.com/forums/general-maintenance-repairs/896968-new-window-motor-spot-q.html
Good luck!
BT
Good luck!
BT
Well the motors are running strong...it's wierd because I was playing with the switch itself the other day and when I pushed the switch halfway up (applied half-pressure) the window went all the way up with no hiccups. When it goes down it still skips a little bit. I think the problem is like what BT said in his previous post...probably something obstructing the track or a stuck wheel.
You have one of about six different things that it could be. 1-stripped gear in the motor(not as common in gm as in fords), 2-stripped teeth on regulator, 3-motor/regulator loose, 4-bent regulator, 5-dry tracks causing the wheels to stick(already been said), and if you didnt buy your car new or had a motor replaced check and make sure it still has the coiled spring on the regulator if not then this will cause the same issues and will also cause motors to go out prematurely.
If that coil was somehow broken or not working the window would never go back "up"...
Have you seen the kind of tension that is on that coil???
The weight of the glass alone ( after in the down position ) would be too much for just the motor to even move at all...
BT
BT
How long did you install auto glass? I have indeed seen the tension on that spring oh so many times! Yes the window will go back up but for how long? I have seen them last anywhere from 1-4 years that way. So have you ever seen the power a window motor puts out? How do you think it is able to pull the window down so fast? The spring is only there to assist the motor on the way up to extend the life of the motor and also to keep the motor from slamming the glass in the bottom of the door on the way down. The window motors on our cars are alot stronger than you are giving them credit for. You act like the spring is doing all the work for the motor.
Um, weight of the glass.
When I disassembled mine and didn't get the spring back in correctly with enough tension it would only go down and not up. That was with a new motor also...
I don't know what to tell you.
That was from my own personal experience...
They must be pretty weak if they have a hard time getting the window back up with the spring installed correctly with minimum binding in the tracks from the rollers sliding and not turning.
So I'd say it's pretty weak yes...
Installing auto glass has nothing to do with the operating mechanics of regulators and motors...
Cheers!
1991, 91, 92, camaro, clarksville, firebird, ls1tech, motor, power, powerwindow, replacement, spring, tension, tn, troubleshooting, window
