When to change patriot double gold springs?
14 Second Truck Club
25,000 miles? It's a F13 cam (230/232-.595/585-114+4) in a forged 383. It's a daily driver and I don't beat on it too bad...
I changed mine at 35k miles with a similar cam profile as yours. I changed them just for peace of mind. The car does seam to rev a little faster now. I would say that they still have some life left in them. If you are going to pull them off and test them, you might as well put some new ones on. JMO
They've only got ~18,000 miles on them so far. I was planning on doing it this summer when it has 25,000 miles on it. I thought it would be ok, since the FMS/Cammotion lobes aren't as aggressive as the comp XER lobes.
1 Post
I am in no way the one to ask this. So I would refer you the manufacturer. The only thing I can give you is my personal exp. .600+ lift cams require extra attention. Thats the cost for the extra power. Nothing in life if free. If I had to guess you could probably get 50k easy. Isn't stock lift around .500 with durations of 203 or so, and c5 z's .525 and a few more degrees of duration. There valve springs seem to last forever. I know a few guys with c5's one with 97 with 129k on the clock, and the other a 98 with 100k. Both guys are bolt on only, never cracked into the motor, both run awesome, both make 350+ rwhp.
i dont know when exactly to change them, but i just bought a used set of patriot heads with "6k" miles on them and two of the inner valve springs on the dual springs were broken...so i probably wouldnt run them too long without checking them.
I broke a dual valve spring on a set of ET LS6 heads i had on my Z06. It broke at about 7k rpm with about 3500 miles on it (fully warmed up and all). Inner spring held didnt hurt my valves. ET sent me a brand new set of springs, retainters, seals, locks, free of charge no questions asked. That was with a 238/242 .608/.612 115lsa cam. I figure if a spring can break new, it can break at any time anywhere. Nothing was damaged, i even drove the car about 20 miles with the broken spring to a friend who replaced the springs for me. I think people are too paranoid about breaking springs, spinning bearings, and bending valves. I say what happens happens. It all costs money.
When it broke it felt like i lost 60hp. Like i instantly felt it when it broke. I was in the top of probably 4th gear around 7k and when i shifted into 5th i knew right away i had no power. I slowed down watched my oil pressure and it was all fine. Got it home and heard the tapping. Found exactly where the tappin what coming from and pulled the valve cover, started it up, and found the broken spring.
