torque arm bushing or tranny mount?
my car makes a noise from the tranny area when i put it in gear. its not inside the tranny though. i think its the torque arm bushing because its not a hard jerk. ive had the torque arm and tranny both off the car before but i did use different bolts for the TA. what do u guys think? 01 TA with 90k
i don't know, but if you use polys for the torque arm, you will notice better traction, well worth the change and if you don't already have a poly tranny mount you should put one on there unless you don't like vibration after 120mph gets a little shakey after 120 with a poly
should i move this to suspension for more results?
i also think i got a bad spindle on the driver side. hear a chirping at slower speeds, mainly when the car sits a few minutes. gets quieter after some driving but deff something suspension wise.
The Poly mount will be alot cheaper. Its $18 at autozone, they just need to order it. If you go the the dealership they will sell you the whole brackets that come attached to the bushings. Here it was around $85. If you go poly, you just reuse the bracket and slide it in.
Oh yeah, the stock torque arm mouts tear easily which makes it a pain to ahve to change it every couple of month. Save time and money and get the poly, I didnt notice any chances compared to stock, but im glad i dont have to change it soon.
yea its kinda like that. thats y i figured its the TA touching maybe the braket because it might be worn out. how did u fix that? i don't really feel it like i would the driveshaft bearings. do u have a different rear? mine could be due to rebuilt salvage.
Lift your car and place it on jack stands. Then move the torque arm, you'll see how it easily moves(at least mine move a lot before i added the poly bushing to the stock torque arm. You will feel a noticable difference.
