ls1 67 camaro radiator
Old 04-19-2008, 08:34 PM
59 camaro's Avatar
Default ls1 67 camaro radiator
can i use the stock radiator and fans off an 00 z28 for the 67 camaro swap?
Old 04-19-2008, 09:46 PM
leonpiper69's Avatar
yup.....
Old 04-20-2008, 06:55 PM
59 camaro's Avatar
this really does not help....anyone else?????
Old 04-20-2008, 07:15 PM
cherryelky305's Avatar
What do you want to hear? that it bolts right in? you can use it, you just might have to fab something up to get into place, a stock radiator for a 67 with a v8 will work too.
Old 04-20-2008, 07:20 PM
Shawn MacAnanny's Avatar
I used an LT1 radiator and fans, same thing. I just drilled through the top flange of the radiator to bolt it to the core support and the bottom a made 90* brackets to bolt the flange to the air dam but it could be done the same to the core support.
Old 04-20-2008, 09:24 PM
59 camaro's Avatar
thanks for everything....thats what i needed...
Old 04-21-2008, 12:59 AM
This is all the pictures i have right now,
Thats a 2002 camaro fan on a '80 el camino radiator, should be similar on most SBC radiators though. Good luck, ask anymore questions you have. If you need better pictures let me know, maybe someone else can post up too, 67rsss used a modern fan on the original radiator, send him a pm maybe he can help more.
Old 04-21-2008, 05:48 PM
59 camaro's Avatar
thanks for the pics
Quick Reply: ls1 67 camaro radiator
