Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Distributorless Ignition for BBC?
Old 04-21-2008, 01:04 AM
qboy's Avatar
Default Distributorless Ignition for BBC?
Is anyone doing this? No distributor or rotor to wear out and shorter plug wires.
Old 04-21-2008, 01:16 AM
6 & 8 Second Club
mrdragster1970's Avatar
Never seen any, & I've been around a day or two.
Old 04-21-2008, 02:31 AM
JUICED96Z's Avatar
Never heard of any pretty much everyone is going digital (including distributor) or regular pro billet.
Problems with the distributor less stuff is its harder to trouble shoot, if you are EFI and dont get a code and are having an ignition problem then you have a lot more posibiities.
With a distributor, if the wires look good, check the plugs, check the cap and rotor.
Plug not firing check the wire, cap and rotor, rocker arms.
Thats all I had to do when my number 5 was not firing. A LS buddy of mine had headaches tring to figure out what was wrong with his ignition.
In a 5 gallon bucket nexy to me, has my entire ignition system minus plugs and wires.
Selling all of it and going full digital........ and maybe a crank trigger.
Old 04-21-2008, 11:09 AM
blown454ss's Avatar
just tuned a 557" ford with that, it uses ls1 coils, crank trigger and a chopped up dist. for the cam timing all ran with an aem
Old 04-21-2008, 07:24 PM
qboy's Avatar
Is there an advantage to not having a distributor other than not having to replace the rotor every so often?
Old 04-21-2008, 10:44 PM
JUICED96Z's Avatar
Depends who you ask on that honestly, each side has advangates and dis advantages....
Cap and rotors are cheap, I paid like $20 for my MSD cap and rotor........
A lot of the faster LS guys have a front mount distributor...........
Old 04-22-2008, 12:17 AM
qboy's Avatar
[QUOTE=JUICED96Z;9200632]Never heard of any pretty much everyone is going digital (including distributor) or regular pro billet.
What does "going digital" mean?
Old 04-22-2008, 01:17 AM
JUICED96Z's Avatar
[QUOTE=qboy;9208165]
Digital pro billet distributor, digital ignition box with built in spark retard.
Big money but worth it and faster then analog.
Old 04-22-2008, 03:34 AM
1997bird's Avatar
Here is a link to a company that makes a distributorless ignition system for your BBC's & SBC's: http://www.electromotive-inc.com/products/xdi.html
Quick Reply: Distributorless Ignition for BBC?
