Still no 5th,6th or rev
something you might want to check if you have an aftermarket shifter with stop bolts is the front stop bolt. when e toi worked on my clutch the vibrations loosened the stop bolt and it backed in toward the shifter, and i got locked out of the tops gears. This was with a Pro 5.0. Worth a check if you have stop bolts!
Ha if you have a pro 5.0 i'd recommend taking the 2 seconds to pop the center console out and check out that top stop bolt. Mine shifted fine, stopped the car, went to start it back up some time later, and no 1st or 3rd. Drove it around thinking something went bad with the clutch hydraulics or tranny, and the next time i stopped and started it, i didnt have 3rd, 5th, or reverse.
