adjusting PHB for new rims
Old 04-27-2008, 01:00 AM
tavi_ws6's Avatar
Default adjusting PHB for new rims
i just got new rims for my car and moved up from 17 inch to 18 inch rims. the tire is still a 275 width. do i need to adjust the PHB or no? Thanks
Old 04-27-2008, 08:29 AM
Viper's Avatar
Should not have to but it's 2 seconds to measure using a plumb bob.
Old 04-27-2008, 09:09 AM
leadfoot4's Avatar
Exactly....Centered is centered.
(BTW, I set mine with a 1/2 tank of gas...)
Old 04-27-2008, 06:07 PM
tavi_ws6's Avatar
ok thanks, im going to check it, does anyone know where a write-up is for adjusting one?
Old 04-28-2008, 08:27 AM
95GreenZ28's Avatar
Is it single adjustable or double?
Old 04-28-2008, 11:39 AM
lt1noob's Avatar
i would like to know this too for when i order mine but, what the hell is a plumb bob
Old 04-28-2008, 11:49 AM
Viper's Avatar
From wiki:
"A plumb-bob or a plummet is a weight with a pointed tip on the bottom that is suspended from a string and used as a vertical reference line. This instrument has been used since the time of the ancient Egyptians by bricklayers, masons, and carpenters to ensure that their constructions are "plumb", or perfectly upright. It may also be used in surveying to sight a point on the ground that is not readily visible. Small plumb bobs are included in the kits of various instruments such as levels and theodolites. They are used to set the instrument exactly over a fixed datum marker, prior to taking fresh readings."
With the f-body, follow this to center the rear end:
http://www.bmrfabrication.com/INSTALL/F-BODY_PHR.pdf
Old 04-28-2008, 12:21 PM
leadfoot4's Avatar
Red-neck plumb bob....Two large hex nuts tied to the end of the string instead of that high falootin pointy thing.
Old 04-28-2008, 12:49 PM
95GreenZ28's Avatar
Haha nice
Old 04-28-2008, 12:51 PM
Viper's Avatar
Heck a fishing bob is fine.....
