Cobalt dyno (for any that care)
Old 04-27-2008, 10:04 AM
ls1wannabe's Avatar
Default Cobalt dyno (for any that care)
To let everyone have a little background on my car it is a 2006 cobalt ss supercharged. The car was not stock but for a day so i never had a true baseline to go with.
The first time i dyno'd the car my setup was
2.5" pulley
60 pound injectors
full exhuast
dual pass h/e
dual pass intercooler endplate
drop in filter
hpt tuned 12.3 afr 23* timing
Those were the numbers, the dyno is a low reading dyno. Most people on that setup put down close to 290 whp but the car ran strong and trapped 110 and moved 42 lb/min through the maf.
In early march i was selected by harrop to be a tester for the htv 1320. For those of you that don't know it is the tvs 1320 the new generation of eaton blowers, just like the one in the zr1 just a liter smaller.
Some pics
htv 1320 supercharger
2.75" pulley
oversized tensioner pulley
60# injectors
autolite copper step 1 colder plugs
dual pass heat exchanger (ran inline with stock unit)
extra surge tank for coolant
r.a.w. 3" cold air intake
ls4 throttle body
cti longtube header 1 3/4" primaries 3" collector
cti 3" catless downpipe
cti 3" catback
hp tuners tuned
devils own progressive meth injection kit
2.5 gallon trunk mount tank
return style fuel rail
walbro gss342 fuel pump
aeromotive fuel pressure regulator
meth was not used for the runs, tune was conservative 11.0 afr and 16* timing.
The meth tune is being worked on and should be able to pull 335 whp out of it. The operator had a little trouble getting used to my car so that is what the bucking on the dyno is. All numbers are sae, thanks for reading
Old 04-27-2008, 10:18 AM
Pipelayaz's Avatar
What are the numbers? I'm on a GOV computer and I can't see the pics.
Old 04-27-2008, 10:20 AM
ls1wannabe's Avatar
253whp on the old setup with the pretty crazy tune 313whp on the new blower and conservative tune.
Old 04-27-2008, 10:21 AM
98camaroLS1M6's Avatar
Congrats, the car should move now
Old 04-27-2008, 10:29 AM
ls1wannabe's Avatar
it does ok, 3000lbs with me in it.
Old 04-27-2008, 10:30 AM
red fury's Avatar
I am impressed! So the factory motor has forged pistons rods ect....? How many pounds of boost did it take with the new blower to reach over the 300rwhp mark?
Old 04-27-2008, 10:32 AM
ls1wannabe's Avatar
The pistons are not the rods are. Im running 25 psi as far as boost goes, it exceeds what the cars map sensor can register. There are other things that are holding the car back that are being worked on as well.
Old 04-27-2008, 10:55 AM
red fury's Avatar
Damn! How much, are you seeing, that the stock pistons can take boost/power wise before they get to the point of being on borrowed time? Sorry for the elementary ecotec questions.
Old 04-27-2008, 11:00 AM
ls1wannabe's Avatar
The problem that most people run into are extremely high iat2's becuase of the stock blower most people nuke piston number 4. This blower runs so much cooler though and plus the mods i have to keep it that way i am not concerned. There are a few people who have pushed over 400 whp on stock pistons.
As far as how much i am seeing i have the stock boost gauge and it maxes at twenty and it gets to that very quick and pushes further and then resets becuase it can not register. I need to get a mechanical gauge.
Old 04-27-2008, 11:34 AM
TurboLark's Avatar
The Ecos are nice motors. I have one in a 1700lb sandrail. It's the 2.2l that I turbo'd. 8.9-1 comp, stock cams, intake and TB with a GT3076 at 15lbs of boost made 266rwhp thru a very inefficient transaxle. Only running 24deg of timing with race fuel, so still some power in there.
Nice setup.
Old 04-27-2008, 11:41 AM
ls1wannabe's Avatar
Yeah im still on stock internals and pushing over 100 whp over what most stock guys make, so i'd say they did a good job.
Old 04-27-2008, 11:51 AM
Slvr00Bird's Avatar
Nice numbers... and now that you have the vid's and all the info out there, all the haters and non-believers can read and be astounded.. .. (yea i've seen a couple of your other threads)
Old 04-27-2008, 11:53 AM
ls1wannabe's Avatar
Yeah, figured i would keep this one in the right place and direction. My other threads can get out of hand quickly.
Old 04-27-2008, 12:03 PM
SnakeStomper's Avatar
Great #'s dude, congrats!
Old 04-27-2008, 12:20 PM
JScamaro's Avatar
Congrats on the car! I would love to have one of those as a daily driver.
Old 04-27-2008, 12:33 PM
raptorws6's Avatar
Very nice numbers.
Old 04-27-2008, 12:50 PM
ls1wannabe's Avatar
Thanks guys,
Js- its not to bad as a daily driver gas mileage is better than stock lol. The car is a little decieving though it kind of feels faster than it is.
Old 04-27-2008, 01:52 PM
JBIRD02's Avatar
Congrats on the #'s, thats awesome!
Old 04-27-2008, 02:06 PM
Mike @ New Era's Avatar
That is a lot of power , couple of questions though :
Why was the smoothing turned down to zero making the graph look real rugged with the harrop supercharger ?
Why did you start measuring data at 5000 rpms with the harrop supercharger ? Was there issues with too much boost down in the lower rpms that were difficult to tune ?
Just curious .
Old 04-27-2008, 02:49 PM
ls1wannabe's Avatar
There was a spike with smoothing on 5 that made tq go to 302 wtq. So to give a more accurate representation of actually tq i turned the smoothing to zero. The runs started at 3400 i don't know why he even started that high. There are no problems with the tune though.
Here is a few more graphs
Quick Reply: Cobalt dyno (for any that care)
