Cobalt dyno (for any that care)
The first time i dyno'd the car my setup was
2.5" pulley
60 pound injectors
full exhuast
dual pass h/e
dual pass intercooler endplate
drop in filter
hpt tuned 12.3 afr 23* timing
Those were the numbers, the dyno is a low reading dyno. Most people on that setup put down close to 290 whp but the car ran strong and trapped 110 and moved 42 lb/min through the maf.
In early march i was selected by harrop to be a tester for the htv 1320. For those of you that don't know it is the tvs 1320 the new generation of eaton blowers, just like the one in the zr1 just a liter smaller.
Some pics
htv 1320 supercharger
2.75" pulley
oversized tensioner pulley
60# injectors
autolite copper step 1 colder plugs
dual pass heat exchanger (ran inline with stock unit)
extra surge tank for coolant
r.a.w. 3" cold air intake
ls4 throttle body
cti longtube header 1 3/4" primaries 3" collector
cti 3" catless downpipe
cti 3" catback
hp tuners tuned
devils own progressive meth injection kit
2.5 gallon trunk mount tank
return style fuel rail
walbro gss342 fuel pump
aeromotive fuel pressure regulator
meth was not used for the runs, tune was conservative 11.0 afr and 16* timing.
The meth tune is being worked on and should be able to pull 335 whp out of it. The operator had a little trouble getting used to my car so that is what the bucking on the dyno is. All numbers are sae, thanks for reading
As far as how much i am seeing i have the stock boost gauge and it maxes at twenty and it gets to that very quick and pushes further and then resets becuase it can not register. I need to get a mechanical gauge.
Nice setup.
.. (yea i've seen a couple of your other threads)
Why was the smoothing turned down to zero making the graph look real rugged with the harrop supercharger ?
Why did you start measuring data at 5000 rpms with the harrop supercharger ? Was there issues with too much boost down in the lower rpms that were difficult to tune ?
Just curious .
Here is a few more graphs
