upgrade injectors?
the later model stock s/c gtp injectors come out to be ~39lb @ ls1 fuel pressure (58 psi i believe)...they can be had CHEAP on the gtp forums, but you have to buy 2 sets because there are only 6 to a set haha. maybe check ebay? that would be my suggestion. they will work jut fine, a friend of mine is using them with a tfs 215 head/donkey dick cam/fast 90 setup with NO problems.
Get the green top 42lbs. You will need them. Make sure you get a tune before you drive with the new injectors. It will be way to rich and you will wash the cyl walls
Moderator
#30 ford SVO red top injectors. <$300. You will need them with those mods. You need to put them on at the place that is going to tune your car for them. You can't change injectors and not have it tunned right away.
