1966 chevy"2" ls1/th350
Old 04-29-2008, 09:17 AM
lsxlowtech's Avatar
Exclamation 1966 chevy II ls1/th350 pro-street 33/10.5W
please look past any bad gramer or spelling, my wife and i just bought this computer. i'm new at this. just wondering if any one is building any thing like this. this project is almost complete. it's a 1966 chevy"2" sedan, pro street car,ls1, mechanical cam,ford distributor,carb.,th350/5700stall/trans.brake, 9"ford with 5.29:1 gears.engine is not dynoed yet, that will be done at the track.i may be able to guide someone. i am an licensed aircraft mechanic/pa autotech/diesel mechanic and metal fabricator,i have a small shop.i am really in to drag racing.pictures to come when i figure it how to do it!!
Old 04-29-2008, 09:25 AM
bczee's Avatar
Sound like a good project going on.. but pictures are a good thing..
How soon do you expect to be on the track and report your "Dyno" numbers ! Any pre-Dyno numbers on the HP ?
Old 04-29-2008, 09:51 AM
ssduane's Avatar
I'm not going full out drag like you but kinda the same line.
https://ls1tech.com/forums/conversions-swaps/845906-my-current-state-ls1-nova-conversion.html
Old 04-29-2008, 02:05 PM
itslow's Avatar
Stock front clip or aftermarket? What are you using for headers - aftermarket brand or home-built?
Old 04-30-2008, 11:36 PM
lsxlowtech's Avatar
Default lots of time in the shop
stock front clip, with rack from a mustang and used qa1's from a f-body,saved $$$$$! i built the headers, i started this project 4-5 years ago then built a house and then came children......... you may know the story! i am getting back in to it, just trying to raise my gear head sons properly. a couple of years ago before stuff was available for this engine i cut the factory corvette manifolds apart to get the head flange, thats how i started.i see alot of fords getting chevy power,14years ago i put 406cu.in chevy in a 1982 mercury capri. i loved to street race 5.0's with an extra 100cu.in they never knew what happened-ha ha! o-back to my front clip the car has gone 10 10 with a different combination, and still has drum brakes on all corners. when i get the pictures on here people will know i'm no stroker! in a perfact world all chassis componets would go in there perfact place but put a late model engine in a 42year old car,and you want to have people like jerry bickel or warren johnson on speed dial.
Old 05-02-2008, 05:28 AM
HuggyBear67's Avatar
I am very interested to see some pictures of what you have done. From your description, it sounds like you used the Wegner/GM front distributor drive cover, right? I am thinking about the same thing and would like to know where you got your accessory drive stuff and balancer. So far, all I have found is an ATI dampner, but not pulleys. I've got a 67 Nova that I want to put an LS# utilizing the stock front clip. I also want to go 'old school' and use a distributor just to be different.
Old 05-04-2008, 02:23 PM
Tom the roofer's Avatar
I'm no photographer but I'll stop over and take some pics for you. Brown Chevy II right ? I ate too much yesterday.
Old 05-04-2008, 03:32 PM
speedyblue's Avatar
heres mine, it took me about 2.5 years, i have done everything myself including building the chassis and making headers. Now i am starting to tune this thing. i am still using efi.
Attached Thumbnails 1966 chevy"2" ls1/th350-100_3140small.jpg
Old 05-04-2008, 06:57 PM
lsxlowtech's Avatar
Default pictures
Old 05-04-2008, 06:59 PM
lsxlowtech's Avatar
Default pictures
Old 05-04-2008, 11:22 PM
lsxlowtech's Avatar
Default i like shinny things
Old 05-04-2008, 11:23 PM
lsxlowtech's Avatar
Old 05-04-2008, 11:49 PM
63chevyll's Avatar
Default lookin' good
Man all these good lookin chevyll engine compartments. I need do something with mine.
I'm assuming you have slip on collectors?
Old 05-05-2008, 08:32 AM
Skele4door's Avatar
It's looking good man. I've always had a soft spot for 66-67 Novas. What was your reasoning for putting a distributor on it though?
Old 05-06-2008, 08:10 AM
lsxlowtech's Avatar
Default true
i welded up slip on collectors with an "h" pipe that runs under the torque converter.
Old 05-06-2008, 08:21 AM
lsxlowtech's Avatar
with the cam i had ground, at the time the ecm would not work,and the controler for the coil packs did not exist. you can't beat a 6al,dist.and a worked over 8156 holley. with a 5700stall speed conv. a trans. brake,=efi throttle response!!!!!
Old 05-07-2008, 11:54 PM
lsxlowtech's Avatar
Default home built
Old 05-08-2008, 12:06 AM
lsxlowtech's Avatar
Old 05-08-2008, 07:39 AM
lowdeuce's Avatar
You dont happed to have any pics of the fenderwell headers during the building process do you? Starting to do a LQ4 swap in mine and am getting ready to make a set of fenderwell headers.
Jared
Old 05-08-2008, 11:38 AM
AmericanMuscle313's Avatar
Your engine setup looks awesome! Are those Katech valve covers?
Did you use the GMPP front dist. setup or fab the setup yourself?
Quick Reply: 1966 chevy"2" ls1/th350
