How MUCH BOOST will the LS2 intake hold?
Old 05-02-2008, 01:37 PM
Jay Johnson's Avatar
Default How MUCH BOOST will the LS2 intake hold?
Anyone use an LS2 intake for 20psi or more?
What's the most psi that is reported with an LS2 intake?
Jay Johnson
Old 05-02-2008, 02:36 PM
daniel6718's Avatar
its as much pressure as the composite can take...id assume 50+ ive heard of 25
Old 05-02-2008, 03:08 PM
LS1Tech Sponsor
hellbents10's Avatar
23 so far.
Old 05-02-2008, 04:07 PM
stevieturbo's Avatar
Try it, and if you burst it, before your engine....let us know
Old 05-02-2008, 04:26 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
<----I'm at 25/26.
Old 05-02-2008, 06:08 PM
venom ws7's Avatar
PSJ any head lifting with that amount of boost???
Old 05-02-2008, 10:57 PM
LS1Tech Co-Founder
Not yet but I don't have a ton of passes either.
Old 05-02-2008, 10:59 PM
ninetres's Avatar
6 bolt set-up? How m8uch torque you making?
Old 05-02-2008, 11:11 PM
LS1Tech Co-Founder
4 bolt still. No idea on torque. When I actually make a full 867rwhp/25psi pass the car should run 15_ mph.
Old 05-02-2008, 11:14 PM
ninetres's Avatar
How much timing? You gotta have some serious cylinder pressure for 4 bolt heads!
Old 05-03-2008, 11:15 AM
LS1Tech Co-Founder
I'm running a 348ci with 8:1 compression, that's why the combo is running a lot of boost. I should say once the car makes like a 900rwhp it should be 16x mph, I was kinda sandbagging there which is lame.
Old 05-03-2008, 01:03 PM
venom ws7's Avatar
PSJ When you ran 9.44 how much boost were you running?? with 8:1 what is the highest boost you run with Pump gas???
Mighty Mouse ran 18-20psi with stock CI LS2 but little heads lifting but I dont know which heads is he running.
Jay Johnson this off topic but there is a very very old vid with Powter Camaro
(with Flame) at the track after 1/8 the T-top ejected is that you??
Old 05-03-2008, 05:57 PM
black98ws6ta's Avatar
20 psi here, customer car.
Old 05-04-2008, 07:17 AM
no title here
skyhighsami's Avatar
I am building a 408 with 8.8-1 and I had the machine shop stud everything. My goal is 1k rwhp, hopefully the intakes are good enough to support the boost i will have to run to makr that power.
Old 05-04-2008, 08:59 PM
LS1Tech Co-Founder
9.44, I had 20 psi set on the controller but had some issues 2/3 track and the car nosed over.
I was screwing around with 16psi on the street this weekend it was fun. I'm guessing I can do about 15-20 on pump gas but we'll see.
Old 05-04-2008, 11:28 PM
Dex
Dex's Avatar
thats what i was thinking
Quick Reply: How MUCH BOOST will the LS2 intake hold?
