Does anyone have a used G.M vette filter/reg that I can try?
I keep on blowing aftermarket filter/regs and want to try a G.M filter instead,but I want to try one and see if it blows up before I go and buy a brand new one.
Thanks.
Thanks.
The return line is flowing fine.All of the fuel that the pump is moving is going through the return and back to the tank and no psi up to the rail.I have put a ball valve on the return so I can build enough pressure at the rail.I have the filter hooked up as follows.3/8 male IN
3/8 female OUT
5/16 return.
I truly think that the partsource filter is of poor quality and I want to try a different brand.I just want to make sure that is the problem before I spend even more money.
Thanks.
3/8 female OUT
5/16 return.
Thanks.
I put a regulator on it instead.I am sure a G.M filter would have worked but if it didn't I would have been out another $70.
I bought an adjustable fpr and the car runs like a champ.
It sounds you had the lines swapped on the end of the filter with two fittings if you were using a 99-07 C5 filter. If you had the return on the inlet and vice versa that could happen. Or just faulty filters but that would be an oddball.
Good you get it working with a different setup.
Mike Norris
Mike Norris
