H/c Vs Ms4 ?
H/c Vs Ms4 ?
Hi , I am perplexed beween those 2 ? what is the good setup ? and good for nitrous and more RWHP and TQ ?
Patriot LS6 Stage 2 59 cc and G5X3 112 LSA
OR
MS4 ?
thanks, Mohammed.
OR
MS4 ?
thanks, Mohammed.
No real maximum limit, but bigger than 150hp nitrous jets, you're going to want a cam designed more for nitrous use. It all depends on how you want to use the car, and how often you want to spray it. Stock bottom end? I wouldn't go any higher than a 150 anyway on a heads/cam car. Some have pulled it off but it's dangerous. The higher cylinder pressure can collapse the ringlands.
You will be fine with a 150 wet, but just to be on the safe side i would add a fuel pump as well. And if your really up for nitrous, have a custom grind nitrous cam made around the heads you want to use.
-Joel
-Joel
I say if your going to spray over a 200 shot, then a cam thats made for nitrous (ex. large split in duration) will be needed. So if you really want the best setup talk to either PredZ or PatrickG to hook you up with a cam. Then buy some heads later on when you get the extra $$$.
^ I agree with him ,either of those guys can spec you a cam that will run what your expecting. I got myself a Walboro 255, but i have heard good things about the Racetronix fuel set-ups.
Its not that its not good for nitrous, but its always a good option to have if you want to have a cam ground for nitrous if thats the route your going to take now and into the future. And im sure either of those guys can tell you what heads they recommend you get if your going with a custom spec'd cam.
-Joel
-Joel
