why use 6.0 manifolds and not ls1 stock manifolds?
Old 05-12-2008, 05:07 PM
blacksskid07's Avatar
Default why use 6.0 manifolds and not ls1 stock manifolds?
as it says why ?^^^^^^^^^
Old 05-12-2008, 05:20 PM
bumpin_records's Avatar
I would think cause the 6.0 manifolds point in a good direction to use them on f bodies. they dont hit the motor mounts or anything.
Old 05-12-2008, 05:30 PM
Reject's Avatar
i'm using stockers on mine FM
Old 05-12-2008, 05:33 PM
30th t/a's Avatar
cheap, extremely durable, easy to find, easy spark plug access, good enough for 1000rwhp...thats all I can think of
Old 05-12-2008, 05:46 PM
scott94z's Avatar
I could not have said it better
Old 05-12-2008, 06:17 PM
yes but why not just use stock ls1 manifolds I plan on doing the riverside forwarded and the passenger side normal mount to keep my a/c
Old 05-12-2008, 09:23 PM
out of all the searched and readings i have done i haven;t found any reason why you cant just use stock manifolds so can someone explain me this
Old 05-12-2008, 09:53 PM
Darren P's Avatar
with the stock ones you have to fab up more Tubeing to get to the turbo. the Pham speed kit used the stock manifolds for a while but they had pipes under the k- member
Old 05-13-2008, 06:44 AM
Reject's Avatar
i'll take some pix of mine in a while to give you an idea, you do have to make alot more piping to run the pipe forward again but you keep all of your accessories in the same spot, it i was going to do it again i would have gotten truck manifolds and used the stock on passenger side and a forward on the driver side, Y them together on the driver side, put the turbo were the normal kits are at (near water pump crank pully area) and run my DP on my passenger side... of course all of this with the BMR K member..... in all honesty it would be a faster way than the way i'm going! oh yeah and relocate the alt to the top side of engine
Old 05-13-2008, 09:18 AM
smokinHawk's Avatar
if pointing the manifolds foward, the truck manifolds clear the steering shaft better then the stock ones, the stock ones will work with a little bit of clearancing.
the truck ones come out better and get things pointed in a better direction, mostly with on the driver side because of the steering shaft.
Old 05-13-2008, 01:34 PM
azceta's Avatar
On the same note is there any difference between the 5.3 and the 6.0 manifolds? thanks
Old 05-13-2008, 02:08 PM
thanks guys! looks like a couple other guys had questions too
Old 05-13-2008, 02:51 PM
smokinHawk's Avatar
no, 4.8, 5.3 and 6.0 are all the same if on a truck or suv
Old 05-13-2008, 07:43 PM
thanks guys!! what do they go for 30 bucks?
Old 05-14-2008, 10:43 AM
azceta's Avatar
Thanks guys I wasn't for sure on if they were the same but they looked like it.
Close I'm getting a set for $70 with the flanges.
Quick Reply: why use 6.0 manifolds and not ls1 stock manifolds?
