Questions about STS
my buddy was tellin me that i should keep the stock injectors and fuel pump; he has been it for a couple of years with everything stock. but everyone i ask is tellin me that i have to get better injectors and pump. what u guys think?
also, he told me to run it with ngktr55 gapped at .3. I went ahead and did that. but i was reading that ngk6s r better for turbos. is there really a big difference?
Lot of info on this. You're having probs for several reasons. Here's a highlight:
1. LT's w/ unwrapped exhaust gives too much surface area to cool exhaust. Result is sluggish spool w/ lots of turbo lag.
2. Stock fuel system is inadequate. Need at a minimum a 255gph in-tank pump and 42lb injectors.
3. W/out a FMIC car will pull lots of timing in warm weather (due to high IAT's) which = low power output.
4. Stock valvesprings will probably begin floating around 5K RPM = crappy power.
5. TR55's .3 bigger in gap is probably still too hot of a plug. TR6's are what most peeps run.
There's more, but this is a generic overview. Again, lots of info out there. Zombie has some excellent threads on this.
well let me ask u guys, how the hell did my friends car survive so long without injectors or fuel pump?
is there any fuel pumps where i dont have to drop down the gas tank to change?
Also, I had 20k miles on my stock block and was getting valve float on the base STS setup at 8 psi. So, I would imagine at 120k miles, that is going to be an issue.
As for the injectors, think about your final goals before buying them. I bought 42's which were fine for the stock block, but even if you only add a cam it wouldn't be enough. So think about 60's just to save the $$ in replacing them a year down the road....I did that, and it was a waste of money.
Anyhow, that's where you saw it. It was just my $0.02 observation.
but u do bring up a good point about the fuel injectors. but i was lookin the sales section, and ppl are not losin that much when they resale their injectors, so i guess they have a good resale value.
with that in mind, anybody got a good place to buy the green top injectors for cheap? i found some on ebay for $350 shipped.
Yachelou, do you have anything in the car to keep track of this stuff (data logging, etc)? I will tell you the best mod I ever did was getting HP Tuners, and learning some the tuning stuff. Tuning a turbo car takes patience and time...and if you end up changing anything on the car, you have to keep paying a tuner to do it. Might as well get the software, and learn how to do it.
step 2 get injectors / pump
step 3 get valve springs
step 4 get intercooler
step 5 get tuned
These steps are not optional if you want your stock engine to live.
Optional but wise things to add:
317 heads (cheap) better flow and lowers comp.
methanol injection
wideband
scan gage to see if knock is happening
