Opinions on the tsp 228r and my setup
Looking at getting the tsp 228r for my birthday (May 24) and just wanted to get some opinions on this cam and how it will match my setup. Car is a 2001 z28 with 3.73 gears, 3000 stall, full exhaust. I will be putting in an ls6 oil pump, ls2 timing chain, 7.4 hardened pushrods, and springs to match the cam. How does this combo sound? Still trying to decide between the 112 and 114 lsa since my car is a daily driver and i don't want to sacrifice driveability too much.
You'll be fine with that cam as a daily driver. I like it although I have been considering a custom cam.
She will run fine in traffic and not give attitude. Sounds pretty good, too. Has a nice rough idle, though not anywhere near as choppy as the Torquer V3 I used to run.
With your gears it will be fun.
Mine starts right up although she does hunt for an idle for a bit.
The 228R is a nice cam overall...not too big...not too small.
R/
Frat
R/
Frat
LS1Tech Premium Sponsor
We really like the 228R camshaft. Joseph recently installed a 228R camshaft and PRC 5.3l heads on a friends car with really awesome results! I think it gained 90rwhp & went 11s in the 1/4 at 6000 ft of air!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
i am running the same cam and before i installed the prc 5.3 heads i ran a 12.2 with this cam, it has great power and it is a really fun to drive with those gears it should pull very nice as well, and for the lsa the 112 is awesome has a nice lope sound to it
I know I'm bringing up an oldish thread, but I was wondering if the car was an M6 or A4?
It is a 6 speed car
__________________
Actually, he quoted me asking if the car we worked on was M6 or A4....I responded that it was an M6...completely different car than the OP is referring to
__________________
I have that cam and love it. I have run a best of 11.74 @ 115 so far and it made 400 rwhp and 375 rwtq cam only. Has good street manners and a nice lopey idle. Cam should work well with your combo. I will be adding PRC Stage 2.5 5.3 heads, Fast 92mm setup, and an ASP underdrive pulley soon. Hoping for 430 rwhp.
Fo sho! Fo Sho! [/Superbad]
__________________
