Will i need a stall???
Old 05-14-2008, 10:16 AM
Ls1Gummi's Avatar
Red face Will i need a stall???
Well i'm putting a cam in my girlfriends 2004 Gto. Will i need a stall?? The cam specs are 224/227 -.563/.569 114 . If so what size??? Not really going to be racing just want to make the car cam only.
Old 05-14-2008, 11:22 AM
Z-RATED94's Avatar
Well seeing as a quality converter will help cut the et as much as the cam, I would say yes. A Vig. 3200 or Yank 3600 come to mind.
Old 05-14-2008, 11:43 AM
lt1noob's Avatar
definately. even if you dont "need" it its probably one of the best mods you could do.
Old 05-14-2008, 11:44 AM
cookba's Avatar
get a stall. anywhere between a 3200-3600 for DD use
Old 05-14-2008, 01:18 PM
Ls1Gummi's Avatar
Will i still be able to drive it until i get a stall???
Old 05-15-2008, 09:38 AM
Z-RATED94's Avatar
Yes! But get a stall and cooler.
Old 05-15-2008, 11:26 AM
cals400ex's Avatar
yes, you will be able to drive it and it will run just fine. i am running a very similar cam with the stock stall. it runs very well. if you are not into racing, i dont' think i would change the stall. then again, if you are not into racing, i wouldn't change the cam. the only reason i see (if you do not care about racing at all) to get a stall would be so the car doesn't want to push through the brakes when you come to a stop. the car will push a little harder after you raise the idle to accomodate the cam.
Old 05-15-2008, 03:22 PM
Ls1Gummi's Avatar
Thanks man this is the exact answer i was looking for. This is my girlfriend car and she really doesn't care to "race". She just likes how a cam car sounds!! Plus it will give her a little more power. I just dont want the car to push through the breaks so bad that it makes it uncomfortable for her to drive.
Old 05-15-2008, 06:22 PM
cals400ex's Avatar
well just see how it is and go from there. it doesn't push too hard in my mind but it is a difference that i can definatly feel. i can live with that, but i like to race too.....so, i am getting a stall. lol
Old 05-15-2008, 07:55 PM
Ragtop 99's Avatar
If she wants lope and stay with the stock stall, go with a 220/224 114. You'll get more power, lope hard enough at 650 rpm idle, and not push through as much.
