Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
starting a 400 build
Old 05-16-2008, 08:46 PM
botlfed's Avatar
Exclamation starting a 400 build
i bought a 406 from my buddy for a screaming deal afr 227 heads but junk internals.i want to buy a rotating assembly should i stroke this and if i do what stroke crank and what size rod will i need?also what will the final displacement be? im putting this in my 93 trans am i cant wait thanks guys
Old 05-16-2008, 10:50 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, i just say leave it stock stroke, get a scat rotating assembly al forged. You are pushing your limit stroking a stock GM 400. 414 cubes is the safe limit and not really worth it, just do a 406 and call it good.
Z
Old 05-16-2008, 11:10 PM
botlfed's Avatar
i was going to go with the k1 technologies crank and rods and je pistons.
Old 05-17-2008, 12:48 AM
RAGENZ28's Avatar
Stay with a 406, it's a lot less work and 10 cubic inches + or - isn't worth the extra money or work I think. When you put 406 stuff in a 400 block it fits without issue, no grinding, no off spec rod length or custom pistons, bolt in the parts and go.
Keep it simple, btw afr 227's are awesome, but I think they need offset rockers so you know if you don't already have them. I had a set of 210's I love those heads, never had an issue and great performance, 10 sec motor passes with a destroked 400 (377") with a pretty small cam and not enough stall or gear and it still ran hard.
Old 05-17-2008, 01:48 AM
1997bird's Avatar
The largest rpm freindly stroke crank that I would use is 3.875". The work involved with clearancing the block is not really worth it in my opinion, unless you have a heavy Chevy. I like the de-stroked version myself, I have had great luck with running the 3.5" or 3.562" stroke cranks.
Old 05-17-2008, 08:02 AM
botlfed's Avatar
what is the stock stroke?it wont need stroked to be a 406 right wont a 30 overbore make it a 406 so i could run the stock stroke with no machine to the block.what would be the advantage of destrokeing it to a 377?
Old 05-17-2008, 10:59 AM
In-Zane Moderator
ZONES89RS's Avatar
The destroke ends up making a higher revving motor.
Old 05-17-2008, 02:43 PM
1997bird's Avatar
The stock stroke is 3.75" and a .030" over block makes it a 406.
Old 05-17-2008, 04:10 PM
botlfed's Avatar
what else would be involved in putting this in my 93 trans am because of the computer?
Old 05-17-2008, 09:16 PM
moge11's Avatar
read up on the LT1 section for this one. Search and you will find the answer.
Old 05-19-2008, 11:47 AM
kenSS's Avatar
k1 technogolgys makes a great products, all though its made in china, there rods and cranks are a nice piece. i've been using them for over 2 years and no bad thing about them. good piece and affordable.
Old 05-20-2008, 09:15 PM
botlfed's Avatar
ive been searching in the lt1 section and cant really find anything can someone post a link thanks
Quick Reply: starting a 400 build
