mild steel
mild steel
http://www.wolferacecraft.com/detail.aspx?ID=236 is this going to be to heavy to affect my times
the only thing im wondering is if i can remove the bar the goes in back of the seats i want to make sure i can lean back lol or maybe make it removable or cut it and weld it in an angle
...it comes powdercoated black. Its easier with a vert, but I think you still need to remove the seats and stuff and you get it in and set up then mark it up for weld if your going to weld it in, if you get the bolt in one though just get it all in and make the marks where your going to drill before you drill anything. Then once its all lined up and everything make the holes and bolt it in.
