Rev Limiter? What do you use?
Old 05-23-2008, 10:01 PM
WS6HUMMER's Avatar
Default Rev Limiter? What do you use?
Since the factory rev limiter cuts fuel and not spark it would be very dangerous on a F/I car to hit the factory limiter. I was thinking about getting the MSD 6LS if I dont have to buy the harness they sell to use it & I like that it has a built in 2 step. What are you guys using? Did a search and couldnt find anything.
Old 05-23-2008, 10:08 PM
gametech's Avatar
Since the factory fuel cut is supposed to be a total fuel cut, it really isn't dangerous. I suppose if you ran a lot of methanol, or a wet nitrous kit, it could be a disaster, since some fuel would still flow.
Old 05-23-2008, 10:13 PM
WS6HUMMER's Avatar
I'm sorry I guess I dont understand what you mean. If your under boost and your fuel gets cut wouldnt it go super lean or detonate?
Old 05-24-2008, 12:51 AM
SilverSS's Avatar
i wanna know too
Old 05-24-2008, 01:29 AM
firehawk618's Avatar
I understand what he's saying. If it completely cuts fuel which i'm pretty sure it does then if there's no fuel there's no explosion and no explosion = no detonation.
Makes sense because otherwise wouldn't there be tons of FI guys blowing ringlands, bending rods blowing head gaskets after a few rev limiter bounces?
I think the main reason it's bad on a s/c motor is because the sudden and fast fluctuation of rpm's has gotta be bad on the blower.
Old 05-24-2008, 06:19 AM
WS6HUMMER's Avatar
I can understand what your saying, it seems like there is potential danger though. I just dont like the idea of it loosing fuel.
Old 05-24-2008, 11:09 AM
stevieturbo's Avatar
Generally speaking a fuel cut should be safe for a rev limiter. Unless you are a numpty and continually hold the car on the limiter.
If you have hit the limiter, you have stopped accelerating....so you should never hit the limiter if trying to go fast
Old 05-24-2008, 11:10 AM
Mine comes up on the rev limiter so fast that if you're not careful it is VERY easy to hit it. Car is still pulling, doesn't sound like it's RPM'd out at all. Sounds like it could rev much higher. I have mine set at 6500rpm's.
Old 05-24-2008, 01:01 PM
I have mine set at 7350 now
Although used to be a little closer to 7000. I dont think Ive ever hit it, apart from on a missed 3-4 shift once.
it seems to take forever to get to it !!
Old 05-24-2008, 10:00 PM
WS6HUMMER's Avatar
So no one seems to be hitting the rev limiter and detonating right? So far so good.
Old 05-26-2008, 11:25 AM
I use an ignition cut. Whilst a fuel cut should be safe...I still wouldnt use one if possible lol. That said. Ive was away racing yesterday, and never once did I hit my rev limiter....even if it is now at 7350..
Seems to rev cleanly to around 7100 though
Old 05-26-2008, 01:41 PM
WS6HUMMER's Avatar
What are you using to cut spark?
Old 05-27-2008, 10:31 AM
Im not using a factory ecu.
Old 05-27-2008, 12:45 PM
WS6HUMMER's Avatar
Oh OK, BS3 or FAST, or something.
Old 05-28-2008, 12:05 PM
DTA S80Pro...its a UK based product.
Quick Reply: Rev Limiter? What do you use?
