what are SVO 30lb injectors compaired to FAST 33lb Fuel Injectors ?
what is the difference between SVO 30 Lb Fuel injectors Compaired to Fast 33lb Fuel injectors ? Cause i've been hearing that alot of people have been running these SVO's 30lb injectors for a little time in there 402 + cid engines ? is this good or not ? what would the DUty Cycle be for the FAST 33lb Fuel injectors i know they will be almost maxed out , but will they work ? OR will i take a Change in running the engine LEAN ?? not enough fuel ?
SVO 30# injectors because they will be acting as 36# injectors will handle more fuel than 33# injectors will. If it will be enough for your specific application is yet to be determined. That all will depend on your setup and fuel needs. If its gonna be more than 450 RWHP or so, I would bet that even the 36# injectors probably won't be enough (or if they will, their duty cycle will be almost maxed out). More than 450 RWHP and I would step up to some larger ones like some 42# SVO's and that should take care of you until you get to about 530 RWHP or so. This is to say nothing of needing a fuel pump to keep up with all of that, but that is all a bit far off from the original topic about different injectors.
