change from stock LS6 intake to ported fast 92MM and NW TB how much H.P.?
Old 06-01-2008, 04:36 AM
odarabla's Avatar
Default change from stock LS6 intake to ported fast 90MM and NW TB how much H.P.?
I just installed my ported fast 90mm intake and Nick Williams TB. My car made 423rwhp and 376rwtrq with everything in my sig and the LS6-intake. I can really feel a difference in the midrange. Just feels like the car response alot better than before. What do you guys think the new #'s will be? Thanks
Old 06-01-2008, 05:19 AM
00T\A's Avatar
You should see a +20-30 rwhp gain with the 92/90.
Old 06-01-2008, 09:12 AM
odarabla's Avatar
[QUOTE=00T\A;9471719]You should see a +20-30 rwhp gain with the 92/90.[/QUOTE
What about rwtrq?
Old 06-02-2008, 09:53 PM
VIPERBLUELX's Avatar
And then there are those that see 10rwhp too...
Old 06-03-2008, 04:45 AM
00T\A's Avatar
That is so true.
But with his mods he should see a 20 rwhp gain.
Also a 10-15 rwtq.
Old 06-03-2008, 08:59 AM
odarabla's Avatar
That is so true.
Also a 10-15 rwtq.
Do you have any track times for your car? I was hoping to get around 440rwhp with the intake and throttle body. I just sent my converter back to PTC to get recut. Then on with the 28" tall tires and off we go. Do you guys think it's possible to get into the high 10's with what I have?
Old 06-03-2008, 10:35 AM
00T\A's Avatar
No track times for me,it's just a street prowler
Depends on your cars weight, suspension and driver mod
Good luck your car should roll.
Old 06-03-2008, 11:44 AM
JPH
JPH's Avatar
Heres my results on a recent car?
Ported LS6 w/stk ported TB and stk maf= 427hp/394trq
Ported FAST92 w/92 TB and 85mm maf= 448hp/399trq
Old 06-03-2008, 12:17 PM
Martin HD-28's Avatar
My personal ressults went from 384 hp to 395. And 370 TQ to 348 TQ. I actually lost on the install.
Old 06-03-2008, 01:48 PM
Yeah a friend of mine installed a ported FAST and NW 90 and lost 10rwhp on the dyno, nobody can figure it out, but the car still pulls harder up top.
Old 06-03-2008, 03:53 PM
allngn_c5's Avatar
21 rwhp gained, was that mid and up top mainly or did she gain down low as well. Even if its peak hp, thats a good gain.
Old 06-03-2008, 04:45 PM
coolformula's Avatar
GM High tech just did this and gained 20 RWHP. Which is about avg I would say. It was a cam only car. So with heads I would say its just going to open it up even more on the top end.
Old 06-03-2008, 06:11 PM
JPH
JPH's Avatar
This was on a 346 w/dart 225 heads and 232/234 camshaft.
Old 06-07-2008, 03:58 PM
JJD49's Avatar
I tried the CHEAPO Typhoon 96 MM intake. gained 14 HP across the board
Old 06-07-2008, 04:04 PM
allngn_c5's Avatar
What exactly is the issue with the Cheapo Typhoon ?? Are they junk or what. Seems like they would get you more then 14 rwhp.
However 14 across the board is better the 14 at peak.
