Help me build bulletproof block
ok, so i spun a bearing and am basically looking at a new block, i want something that will net me more power, and also be near bulletproof, i will be adding a 90mm intake and throttle body and basically spraying the 100 shot, just unsure of what block to go with and what kind of forged internals
bulletproof?
that nice new Billet Dart block should do the trick
http://www.dartheads.com/products/ch...let-block.html
just make sure everything in the rotating assembly is forged...
between both of those, you should have a really solid engine...
just get your wallet ready for it
No need to go iron for a 100 shot. mine as well just stroke your stocker to 383, and get forged internals. You don't need a 'super-expensive' setup for a measly 100 shot. A better investment would be in good set of heads.
What cubic inch are you thinking? You can build a rock solid 347 just as easily as a 408. It just depends on what your goals are out of the engine as well as your budget. I did recieve your PM and will reply to it shortly. When you get a few extra minutes give me a call or shoot me your number and I'd be happy to give you a call to discuss some options with you.
Jon
Texas Speed & Performance
Jon
I would get the stock block blueprinted and at the same time get your bearings done .10 over (if you don't know that, you probably know but just makin sure)
Built internally and blueprinted alluminum block would be a good price and could handle insane power, more than you are hoping for, and would be lighter and more cost effective. I think if you do go iron block you should scratch your 100 shot idea and either go turbocharged or more nos cuz its just a wast having such a strong setup with such comparatively small hp in relation to what it can handle.
Substantialy more given the proper attention. But its about the budget. IF you want big Hp it comes at a cost.
But as pointed out earlier that's not always the point.
No a 408 isnt overkill, but its one of those things thats relative and everyone will have a different opinion.... I have a 457 in my street car..LOL
