replacing springs and shocks, what else?
Old 06-06-2008, 12:09 AM
cals400ex's Avatar
Default replacing springs and shocks, what else?
I am in the process of putting some strano springs and KYB shocks on my car. I want to replace the insulators just to be on the safe side. I have noticed that there is upper and lower insulators in the front and only uppers in the rear. Should I replace all 3 of these if I am going to do any of them? Also, is there any other parts that I should replace with these? thanks
Old 06-06-2008, 12:24 AM
cookba's Avatar
front shock mount. if your gonna replace one insulator you might as well do them all since the springs will be out. when you put the springs in make sure the pigtail faces the rear of the car.
Old 06-06-2008, 12:43 AM
cals400ex's Avatar
those front shock mounts are over $100 each. if i need them, i will get them. i don't know much about it so i will have to take your word for it. when you say pigtails, is that just the end of the spring? and does this apply to front and rear springs? also, is that for the top or the bottom of the spring?
Old 06-06-2008, 02:01 PM
99Bluz28's Avatar
Rear springs, on the bottom.
Old 06-06-2008, 04:15 PM
DarkhorSe_SS's Avatar
not sure if my back springs are but what if they are not facing the rear? jus curious to know
Old 06-07-2008, 01:52 AM
cals400ex's Avatar
my stock rear springs on the bottom are facing the left side of the car....
Old 06-07-2008, 01:53 AM
cals400ex's Avatar
by the way, would new shock mounts be a good idea?
Old 06-07-2008, 09:53 AM
z28bryan's Avatar
Are you talking about the rubber piece that the springs sit on? You probably don't need to replace those. If the bolt at the top of the shock shaft is seized though, you might want to just cut the stock shock shaft and put some new mounts in.
Old 06-07-2008, 11:05 AM
cookba's Avatar
sorry i meant strut mount. allot of times these are pretty worn and when you go to istall new shocks they are either all rusted or even fall apart. I bought a set when i put my Koni's in, but when it came down to it i didnt need to. I think it also depends on where you live. i.e. i live in FL and SoCal so we dont have corrosive salts and etc on the roads to eat at these things
Old 06-07-2008, 11:07 AM
cookba's Avatar
OH and its recommended the springs pigtails face the rear to help prevent one side of the car sitting higher/lower than the other, yes pigtail means the last loop of the spring.
Quick Reply: replacing springs and shocks, what else?
