Will Procharger make enough CFM??
Old 06-06-2008, 06:22 PM
GTFORMULA's Avatar
Default Will Procharger make enough CFM??
I am putting together a 408 with ETP 245 heads, custom cam not determined, and 1-7/8 headers. My question is will a Procharger P1SC push enough CFM to make boost above 12 PSi and be effecient. I usually do turbos but Ive got the blower and figure I might use it. Thanks for any input.
Old 06-06-2008, 06:25 PM
Juiced's Avatar
nope, not a p1
Old 06-06-2008, 06:48 PM
Jake@EPP's Avatar
A p1 will be maxxed out trying for 10psi. A d1 will be the best bet for sure.
Old 06-06-2008, 06:50 PM
93formto98T/A's Avatar
I'd say at minimum a D1sc but an F1 series would be ideal. You may say 12lbs now but soon you'll want more... Sell the p1 and buy an F1.
Old 06-06-2008, 07:14 PM
EPP
EPP's Avatar
I agree, you're going to need an F-1A. With my 408 with AFR 225 heads, we're seeing 18 psi in the heat of the day with the impeller speed maxed out. We see 20 psi when it is cooler out at night. http://www.exoticperformanceplus.com...Car.php?car=12 Bob
Old 06-07-2008, 07:55 AM
GTFORMULA's Avatar
Thanks for the responses. EPP I PMed you a while back about this and to get a bunch of prices from you but I never heard back.
Old 06-07-2008, 10:11 AM
lmt0705's Avatar
F1A with the race bypass valve from EPP gets my vote, theres nothing better then driving a jet on the street
Old 06-07-2008, 03:23 PM
BLNLS1/RX7's Avatar
Sure wont,sorry.
Old 06-07-2008, 08:28 PM
EPP
EPP's Avatar
Thumbs up
Thanks, I'll get back to you tomorrow. Bob
Quick Reply: Will Procharger make enough CFM??
