Difference in bullet style mufflers
Old 06-10-2008, 06:59 AM
TORCHD 02 TA's Avatar
Question Difference in bullet style mufflers
I am looking to buy a LMI muffler. But what are the difference between LMI, LMII, Borla XR-1, Flo-Pro Twister, Sweet Thunder, Dynomax, Power Stick.............
or i can buy this one from Summit. Looks like all the above
Old 06-10-2008, 07:36 AM
Mikes96z's Avatar
I think the packing material inside the muffler is what separates them. BTW the LM bullet is loud as hell!!!!
Old 06-10-2008, 07:46 AM
Well the LM bullet will be going after my merge on the y pipe
Old 06-10-2008, 07:54 AM
z28voodoo's Avatar
its the inside as stated above. LM1 is just a hollow pipe. im installing the Magnaflow this weekend ill post some pics of it. its got small pits inside that trap the sound and make it sound great. if you have LTs or gonna get LTs i probably wouldnt get the LM1. i thought i could handle it and at times it does sound awesome but 1st and 2nd gear and part of 3rd its raspy as hell! raspy as in sounds like an old beat up truck than a muscle car. but if you want a used one im probably getting rid of mine..
Old 06-10-2008, 08:25 AM
I have TDs and a cam with LTs. I am going back a custom Y and GMMG c/b. i am running catless so i was wondering what bullet to stick after the merge to quiet the rasp down a bit. I have had the MagnaFlow MagnaPack mufflers on with my X pipe before as well and my mustang.
How much you want for your LMi muffler?
Old 06-10-2008, 09:05 AM
ls2 bait's Avatar
an lm1 is a waste of time. get the lm 2 if u want a bullet. the lm1 is hollow.
Old 06-10-2008, 09:17 AM
if i am not mistaken yours is a LMI right?
Old 06-10-2008, 09:27 AM
ls2 bait's Avatar
no its an lm2.
Old 06-10-2008, 09:52 AM
no its an lm2.
did that clear up the rasp a bit w/o running cats? But i forgot your running a dual/dual
Old 06-10-2008, 10:24 AM
dug
dug's Avatar
Put a powerstick muffler in the ipipe since youre getting the chambered catback.
Old 06-10-2008, 10:25 AM
why the powerstick over LM, ST, Flo-Pro, Dynomax?
Old 06-10-2008, 10:37 AM
dug
dug's Avatar
cuz its the least restrictive that will actually give some tone.
LM probably isnt gonna do much, ST necks down to 2.75" core, flopro looks restrictive, dynomax would work but the powerstick will probably sound better.
THe best way to get rid of rasp would be to run a pair of mufflers in the ypipe if you can get them to fit. Powerstick is only 3.5" diameter so you might be able to squeeze in a pair.
Old 06-10-2008, 03:50 PM
King Nothing's Avatar
when i first got my exhaust done for my true duals it was 2 2.5" pipes coming off my headers goin into 2 LM1's before dumping before the axle and holy **** that was loud!!!! well i took it back after 2 weeks and had a crossover pipe put in to make it an H-pipe and that quieted it down abit but made it a deeper tone. i know have the pipes coming out the back under axle and i think it sounds awesome! i'm not runnin cats either. i'll admit yeah it's raspy at times but not raspy like an old farmers truck IMO
Old 06-10-2008, 04:09 PM
LS1-NAVY's Avatar
borla XR-1
Old 06-10-2008, 07:42 PM
So then which bullet type muffler that will not be restrictive for my exhaust?
LTs + O/R Y + GMMG
Old 06-10-2008, 08:05 PM
bad6as's Avatar
do you have a cut out?
from what i have gathered the moroso sprail flow is the quietest bullet. i had long tubes, ory and a slp loud mouth II cat back could be tame but it was still loud. im trying a new idea, y-pipe, then cut out, the the sprial flow, then 3" over the axle. not sure if adding a 2nd bullet (sprial flow) would tone it down more)
Old 06-10-2008, 08:39 PM
No i do not have a cut out, i am working on that right now.
i will prolly jsut do a LMII
Old 06-10-2008, 08:41 PM
bad6as's Avatar
videos of my loudmouth II
http://videos.streetfire.net/search....erm=bad6as&p=1
Old 06-10-2008, 09:13 PM
lilbuddy1587's Avatar
LTs + O/R Y + GMMG
Like I've already mentioned as well as dug, the powerstick. It's a bullet style chambered muffler. The 3" version flows 2k+ CFM....Thats more than enough Not only will it add to your chambered sound but it will take care of any rasp issues as well.
Now if you're looking for a stainless steel bullet that will flow well (1300+ cfm) but also tone things down a bit then the Borla XR-1 will do the job.
Old 06-10-2008, 09:15 PM
where can i get the power stick
Quick Reply: Difference in bullet style mufflers
