Just threw on an intake NO OIL PRESSURE!!!
well i put a bbk intake in and checked all the connections it all looked fine and turned on my car for 10 seconds and saw that there was no oil pressure going through it.
i turned it of and here i am what can the problem be and how can i fix it.
thanks
thanks
Did you break the oil pressure sending unit? It's on the back of the block, closer to the drivers side bank.
Common mistake when putting on an intake... I think you need a 1" deep socket to take it off and put the new one on.
It doesn't plug into the intake, but the brake booster hose on the back of the intake has to go over the sending unit when you put it on. Pretty much everybody breaks it at least once. Time to take the intake back off.....
You def. broke the oil pressure sending unit. I did the same thing on my '01 SS when I swapped to a fast 90/90. It was a PITA to replace it on the back of the engine becasue it broke off so close to the base of the unit. Not fun!
Nice job noticing the lack of pressure and shutting the car off quickly.
I had a customer today drive their car ~30 miles to the dealership and tell me it doesn't have any oil pressure. "The sending unit was bad." The customer actually thought it didn't have oil pressure though...and drove the car...
