what front springs in need ?
hi , when i bought my car it's like that picture from front is higer than rear so what springs i need for front ? and i need rear or only front , i want the car from front lower than rear , and how much inch's (front-rear) my car dropped ?
pictures
front
side
rear
question : what those springs ?? in this picture
pictures
front
side
rear
Pontiac SLP, looks like the previous owner of your car removed the rubber spring isolators that sit on top of the rear springs. This usually drops the rear by 0.75". If you want to lower the front end too, I would suggest either lowering springs like BMR, Strano or Eibach (LT1 only) for all four corners, or cutting about 1/2 to 3/4 of a coil from the bottom of the stock front springs, or best of all, Koni SA shocks on all four corners with the front springs on the lower mount.
Yeah heres a guide to the hose mode or replacing the rubber isolator with heater hose. you could just do the opposite to level it out if the previous owner did the mod.
https://ls1tech.com/forums/showthrea...1&page=1&pp=20
LS1Tech Premium Sponsor
Hello, we offer an excellent spring for your car that will drop the car 1 1/4" yet retain very good ride quality. I sell all four springs for $229.95 or if you need just front or rears they are $125.95 per pair. If you have any questions please give us a call our tech/sales dept is open MON-FRI 8:30AM-6:00PM EST. Here is a link to our site and a couple of pics. The car in the pic has our springs installed.
http://www.bmrfabrication.com/F-bodySuspension.htm
