RX7 LS1 Gauge Cluster issue
Apparently the RX7 LS1 i'm looking at has a non-working gauge cluster. Says he checked all the signals from the wires and had the gauge cluster repaired. Still no properly working gauge cluster. He says that's quite sure that this is a power/ground issue. What steps would you suggest to rectify this problem?
http://members.tripod.com/~grannys/manuals.htm
There are the swap manuals that Granny's made. Just pick the 3rd gen one for your motor and find the gauges section.
LS1TECH Sponsor
Ughhhhh Been there done that, my red fd had some wiring issues and the cluster was bad....... After spending way to much time to trace down the problems I just said screw it and installed aftermarket gauges....
LS1TECH Sponsor
It got a bit more touch up after that, I could not find a tach to mount in the dash like a would have liked to so I just reused the stocker..... I also rewired the stock fuel sending unit to be used in this setup.... worked pretty darn good!
