I Have A Block Outta A 06 1500 2wd Silverado Truck Idk
yah are you putting the motor into your car or truck because it does not matter. just get 4.00 pistons for a stock 6.0 block or if your going to bore it, get the correct size. i am with shortchevy, dont really understand what the problem or question is.
what i was asking is i have that block and i messed up my pistons do not wanna bore it out are nething needed to see if i would be able to get a stock size piston but aftermarket lk with the valve release
126-11514 Diamond Pistons LS1 Forged Dished Piston set w/ -13.7cc Dish, 4.000" BORE / 3.622" Stroke / 6.098" Rods / 1.336" Comp Height / .945 x 2.950 Wrist Pins Included $720.99
for a stock motor. 4.00 bore/ 3.622 stroke from thunder racing
this is just an example because there are more to choose from. just call any of the vendors to the right and ask them for what you want.
