Engine Bay Project Complete
finally i have the engine bay presentable and showable. i still have a few spots that are hard to see where theres overspray and ill get around to fixing that sometime, but all in all i was pleased with how this turned out since ive never done any kind of body filled or that type of thing. i just wanted to make this thread to show what an avg person can do on their own w/o paying a body shop an arm and leg, everything was doen with the motor stil in the car...also a painted LS6 intake is in a month or so, but heres where i am now...feel free to comment and give const critism if ya see anytihng that can be changed to look better.
if ya missed my last threads, heres what ive done:
-complete wire tuck (both fenders)
-all holes filled in and shaved
-everything painted w/ single stage acrylic enamel w/ HVLP gun.
-relocated battery, traction control, an fuses boxes
-painted valve covers, TB, MAF, STB, bumpers support, and all brackets.
-stainless nuts, bolts, and washers
-lexan covers to hide battery cables and fuse box hole, and pcm, all painted.
-shaved corvette FRC, painted silver.
just for comparison....heres what it looked like when i got the car a few years back
just pull the fuse boxes up, remove the holder they sit it and youll see is hole that just big enough to cram the fuse boxes throgh, one at a time. when you do it, make sure you position them so the labels are facing down so you can stil lchange them iff nessecary. the boxes will be relocated in the compartment where the foglights are on a camaro, not sure about the birs tho...
Badass man, especially after looking at the before and after pics. How are you holding those lexan pieces in place? Have you considered covering up the ps wall where the wiring tucks into the wheel well? This stuff is inspiring for me, but it takes time and patience which I'm not really good with.
thanks for al the compliments ppl...evaporate, as far as hiding the wiring going into the wheel well, im not sure i know what youre talkin about....elaborate some more? im always tryin to find ways to hide everthing and still keep things functional at the same time! are you talkin about the ABS unit and the brake lines?
