top to bottom
Old 07-02-2008, 03:01 PM
97z28nightmare's Avatar
Default top to bottom
anyone know how a lt4 hot cam and heads will work with a stroker bottom?
Old 07-02-2008, 03:47 PM
connexion2005's Avatar
The cam wouldn't be enough for it really and that's assuming your talking about a 383. You really should look for something with above or around a 230 duration and atleast .540 lift on 1.6rr...
Just some advice I suggest.
Old 07-02-2008, 03:56 PM
kierstyn's Avatar
You would also want better flowing heads unless you wanted to have the lt4 heads worked.
Old 07-02-2008, 05:28 PM
96capricemgr's Avatar
Really bad idea. The LT4 stuff is not worthwhile.
Old 07-02-2008, 06:42 PM
1redta's Avatar
Default re
we put it on a buddy's car, that thing ran great with a stock stall and 2.73 gears. it had torque every where, if you have yourself a GREAT deal on the parts/install I would do it again. Art
Old 07-02-2008, 07:09 PM
StealthFormula's Avatar
Assuming a 383 that would be a very very mild setup and IMO not worth doing. I would go with a cam with atleast 230 duration on the intake but thats just me and of course do some port work to the heads.
Old 07-02-2008, 08:03 PM
so which would be better individually, the lt4 cam and heads or the 383 bottom end with some head work. im not really sure which road im gonna go with this car. honestly i was just gonna do the lt4 top end with a procharger. anyone with experience with those?
Old 07-02-2008, 08:12 PM
mightyquickz28's Avatar
Well with the Procharger you don't even need the cam or port work. The Prochargers gonna get all the air you need to go skating down the street in that car.
Old 07-02-2008, 08:16 PM
im lookin for about 550rwhp, i dont think ill get it with just the procharger, and i really dont wanna run over 10-12boost
Old 07-02-2008, 08:39 PM
I see varying claims for HP per pound of boost. Some as low as 8. Others as high as 25. Mine is supposed to be about 600rwhp at 12 to 14psi. It's just a 355. That's theory though. I've got to get the spark issues taken care of (long, long @ss story). Whats this in your sig about an LS1 computer and harness swap? Is that being done successfully?! Tell me about it if it is.
Old 07-03-2008, 02:34 PM
yeah, akron hp, in akron ohio. i was talkin to them and mentioned i was gonna get my comp reprogrammed in texas through madz28.com to get rid of the rear 2 o2 sensors and a mild tune and the guy came back and told me about this swap they supposedly do, which will get rid of the opticrap system and give a full ls1 harness and comp swap. quoted me about 1200 for the swap labor and dyno tunin. i need to talk to them more about it when i go do the first couple dyno pulls in this car. i will let you know more when i find out, or give results if i get it done
