going to to buying tuner
in going to buying a tuner and i have a few in mind. which ones will i have good luck with. will be changing the the speedo due to gears and would like to try to fix my popping noise from my exhaust on decel. i think it might be a lean back fire.
LS1TECH Sponsor
The decel popping probably cannot be fixed with a handheld, our software allows total control of over 400 editable parameters for a 99 LS1 Fbody as well as a full functioning scanner, the ability to apply Real Time Tuning custom operating systems that allow you to tune dozens of tables in real time and a huge supported vehicle listing.
If you have any questions about our product or capabilities you can ask here or by email at sales at hptuners.com and we'll be more than happy to assist you.
I'd bet money you still have the AIR system and you have a check valve that is leaking. I had the exact same problem fixed after i removed the AIR sytem.
HP tuners is some very good tuning software i love mine.
Typically the popping exhuast on decel is caused by excess fuel lighting off in the exuast pipe. Have you had your PCM tuned before?
DEX thanks alot for the info on the popping....i blocked off the main line going to the AIR system and the popping went away. thanks for all the input on the tuning stuff fellas.
