Least expensive option (without laptop) for flashing between NA and Nitrous tune?
Old 07-05-2008, 01:15 PM
WizeAss's Avatar
Default Least expensive option (without laptop) for flashing between NA and Nitrous tune?
Prefer a handheld...... bring it on... what are my options?
Would be nice if you could just swap PCM's back and forth.... too bad it needs a crank position relearn... wonder how much a crank position relearn tool costs? Tech 2's are expensive.. what else does this?
Old 07-05-2008, 02:33 PM
Doc
Doc's Avatar
We can do a custom operating system that will essentially give you two tunes at the flip of a switch on the fly.
Old 07-05-2008, 04:48 PM
WizeAss's Avatar
how much? and what?
I already have couple of good tunes..... both NA and Nitrous.
Old 07-05-2008, 05:12 PM
slow's Avatar
sct xcal2
Ryan
Old 07-05-2008, 05:22 PM
pHEnomIC's Avatar
Hptuners or efilive are able to edit a couple tables that adjust timing and fueling(i think 98-99 can't do fueling though) in relation to intake air temperature.
Basically, I have a relay that is triggered when i arm my system, it replaces the intake air temp sensor with a fixed resistor that makes it read the lowest possible temperature and then on the table i pull timing and adjust the fueling for it.
Working flawlessly for me so far, there's a lot of info on this site if you search, lemme know if you have any questions.
Old 07-06-2008, 03:39 PM
WizeAss's Avatar
$479.00 just to go from a NA tune to a N2O tune seems kinda pricey.
Also the folks that tuned the car used HP Tuners, I wonder if SCT will work with a HP Tuners tune... or can a SCT Dealer scan the file that is in the car and put it on the XCal2?
Old 07-09-2008, 08:57 AM
WizeAss's Avatar
any feedback?
Old 07-09-2008, 09:19 AM
RZRSEDGE's Avatar
I think what Doc is referring to is COS 5 in EFI Live. Not used it myself as I use HP tuners; but it seems to be a convenient and cost efficient way to do what you're asking about. I'm not sure of the price though. I would also as pHEnomIC more about the setup he's proposing. I've read a little about it and there seems to be a lot of success with this method also.
Old 07-09-2008, 09:30 AM
stevegrizzle's Avatar
If you have efi live you could COS 5 it and run on n20 tune when your nitrous is armed.
I would just bite the bullet and buy efi live......its only a 1 time cost, unlike HPT.
Old 07-09-2008, 09:49 AM
LS1Tech Sponsor
Mike@Diablosport's Avatar
A Predator will allow you to accomplish this as well.
Thanks
Mike
Old 07-09-2008, 11:01 AM
WizeAss's Avatar
Thanks
Mike
with an HP tuners tune? Will it scan my existing tune or can I send you a file to load onto one?
Old 07-09-2008, 12:00 PM
TAQuickness's Avatar
EFILives V2 hardware will soon have the black box flashing capability you're after. Live also has COS5 that will allow you to utilize a single tune for your application.
What ever you end up doing, tuning software is a good investment.
Old 07-10-2008, 04:26 AM
RZRSEDGE's Avatar
HP tuners is also a one time cost. I think the price per vehicle tune is comporable; but I'm not 100% certain.
Old 07-10-2008, 07:23 AM
slow's Avatar
he is talking about the extra cost for the custom OS upgrade.
Ryan
Old 07-10-2008, 08:21 AM
^ right, and credits for SD tunes, adding 2 and 3 bar maps ect ect ect......
Old 07-10-2008, 09:58 AM
LS1TECH Sponsor
foff667's Avatar
Starting with 2.22 which was publicly released yesterday makes it so that once you license just 1 of our custom operating systems you get ALL of them for free ie if you license the 1 bar SD COS you get the 1 bar MAF RTT, 2 bar SD, & 3 bar SD all at no added cost!
Old 07-10-2008, 09:36 PM
WizeAss's Avatar
here is what I want:
Handheld device that stores 2 tunes.....
1 for NA
1 for Nitrous
using my existing HP Tuners modified tables in my existing PCM....
for a lower price than 500.00...
DOES THIS EXIST?
I am sure if Charles Beyerch where still around and got the V8 platform off the ground I woulda been able to get this. He had a tuning suite that worked with Palms and smartphones or something.
Old 07-12-2008, 11:12 PM
Black Sunshine/ 00SS's Avatar
All you are changing is the timing, right? Cant you accomplish that with HP tuners?
I have an extra ecm, and thought that I would be able to switch them out, if needed. $75 to $100 for extra ecm, then reflash with your stock vin.
Old 07-12-2008, 11:17 PM
Frost's Avatar
1 for NA
1 for Nitrous
DOES THIS EXIST?
I know of a $50 solution that is *exactly* what you want, but it looks like I can't tell you about it until Monday or so...
Old 07-17-2008, 12:54 AM
WizeAss's Avatar
Monday yet?
