Front Turn signal bulb sockets?
Old 07-07-2008, 08:38 PM
MOWNED's Avatar
Default Front Turn signal bulb sockets?
Where can I find turn signal bulb sockets for the front of my WS6? Not from the dealer..
I also need a ebony seatbelt guide for the drivers side. My dealer is a rip off does anyone know where I can find this stuff online?
Old 07-07-2008, 11:35 PM
Copy & Paste Moderator
VIP1's Avatar
You can get the turn signal sockets from AutoZone for about $8.
Old 07-08-2008, 02:56 PM
Bird Man's Avatar
yes---and they are usually right out in the lighting area.
Old 07-09-2008, 03:04 PM
ICRAZY6's Avatar
Get the part numbers from the stealership then check out GMpartsdirect.com
Old 07-15-2008, 02:12 PM
blubyu02's Avatar
i went to the local salvage yard and found 2 of the light bulb sockets, autozone sent the wrong ones twice so i went found my own lol
Old 07-21-2008, 09:55 PM
ManicMechanik's Avatar
I got them at O'Reilly's for $3.70 ea.
Old 07-22-2008, 06:08 AM
qwk93ta's Avatar
I got mine at Autozone......I did not cut the three wires. I took apart the new socket and used the old wiring. There is a good write-up on how to do this on LS2.com.
Old 07-23-2008, 12:44 PM
Captainofiron's Avatar
im gonna have to do that also, my turn signal housing started leaking a bit, and water was accumulating inside, well I guess it shorted the pigtail because the connectors were all melted and the bulb had shattered.
but even if you do cut the wires its an easy fix.
Old 07-24-2008, 08:26 PM
papawsls1's Avatar
Dude, go to a junk yard if you don't want to go to a Pontiac dealer. The socket can't be that much. The belt guide is only $15.00 brand new, I just bought one.
Quick Reply: Front Turn signal bulb sockets?
