It Finaly Runs
It Finaly Runs
After 7 months of working on the car it finaly started up. on the first try. The smoke is the assembly lube that coated the car. Here are the specs of the car.
355 with Forged pistons 11.3:1 compression ratio.
Lightly Ported Trickflow Heads.
Comp XFI280 Cam 230/236 .574/.570
Pacesetter Longtubes into an ORY into a Hooker Catback.
Custom Tune from AZTPI.
30lb SVO's
30lb SVO's
well i just noticed you are in the phoenix area. if it still needs a tune i would reccomend Sean at Top Gear MotorSports his number is 480-461-0240, he uses tuner cat and did an awesome job tunning my car after i got my cam installed. Tell him Ben sent you, and its 200$ BTW.
I called him earlier and he recommended a pcmforless tune. I was told by a couple other people to go to AZTPI so thats where I had the base tune done and then it will be tuned further on Friday. Does anyone know what would cause it to idle for about 40 seconds then the idle goes down until it stalls out?
