Spark Plugs
Spark Plugs
Im useing the cheap ngk plugs now they been in about 1 year I think there already shot feels like there starting to miss car is serging at times and pulling to one side sometimes.
Anyone using autolites platinum plugs, if there no good I can just get delcos
I change my plugs so often I am buying them by the case...no ****. Getting better at reading them anyways
NGKs are not horrible and another set should be fine.
I am personaly useing Auto lite racing plugs. AR94's and AR93's for the street and AR474's and AR473's for the track
I ran NGK's in my ls1 and changed them every 10k miles. They were just so cheap I would literally just do them on a Sunday if I was bored...
They always worked great for me also...
it pulls slightly because the motor isnt running straight 3 fire on one side and four on the other. I think I mite try the autolite platnium they sell 2 packs at walmart cheap.
I got them bocsh peices of **** o2's they could be going bad the car is running like ****
You better get that taken care of. These motors make a ton of power. First it starts off with just making the car pull to one side, if you let it go long enough it might pull the entire planet it out of it's correct orbit. Please, for mankind's sake, get the car fixed.
this is a joke right?
if not I'm sorry and do not mean to insult you due to your lack of knowledge of your car
The car will not pull to one side or the other unless maybe it has a TOP Fuel motor in it and it lost 1 bank
really though..there is something else causing your alignment to be off then the reasons you have stated.
good luck sorting it out
my old 280z dropped a plug one time. everything around me stopped. not sure what happened. either, A. the aliens probed my poor little car, B. the bitch went plaid, C. i found the magic button in the car to induce light speed at will.
needless to say. we don't need amateurs hitting ludacris speed in the middle of traffic and disrupting the space time continuum. please. get the plugs fixed.
