Anyone have a SVO 42# Offset table for LS1?
Old 07-12-2008, 07:35 PM
y2konyxss's Avatar
Default Anyone have a SVO 42# Offset table for LS1?
Anyone have a SVO 42# Voltage Offset table for LS1?
Old 07-13-2008, 10:05 PM
405HP_Z06's Avatar
I've been looking for this also.
Old 07-13-2008, 11:01 PM
Haans249's Avatar
There is no real adjustment for the voltages. I have the excel spreadsheet that was created a while back for the voltage adjustments, and it did some funky stuff. Last I checked, the best thing to do is to just leave it alone. The only "negative" effects of running the stock voltage adjustments is SLIGHTLY rich afr's on decel, and I'm talking about 13.5-13.8 for me, and thats the extent of it.
Old 07-13-2008, 11:09 PM
y2konyxss's Avatar
used this with my hptuners
Adjusted my Injector Voltage Offset to this:
10.95598 10.98650 11.04753 11.07805 11.13909 11.76471 13.29061 15.01488 15.10643 15.18273 15.24376 15.33532 15.42687 15.54894 15.64050 15.74731 15.86938
4.63874 4.66926 4.73030 4.77607 4.80659 5.11177 5.81369 6.63767 6.74449 6.82078 6.89708 6.98863 7.04967 7.15648 7.27855 7.38537 7.52270
3.69268 3.73846 3.78424 3.79950 3.81476 4.05890 4.62348 5.24910 5.34066 5.37118 5.41695 5.47799 5.52377 5.61532 5.66110 5.73739 5.81369
2.76188 2.79240 2.80766 2.82292 2.83818 3.02129 3.41802 3.86053 3.90631 3.93683 3.95209 3.98260 4.01312 4.02838 4.05890 4.07416 4.07416
2.34989 2.36515 2.38041 2.41093 2.42618 2.56352 2.88395 3.26543 3.31121 3.32647 3.35698 3.38750 3.40276 3.41802 3.41802 3.46380 3.46380
1.90738 1.92264 1.93790 1.96841 1.98367 2.09049 2.38041 2.67033 2.70085 2.71611 2.71611 2.73136 2.79240 2.79240 2.80766 2.80766 2.82292
1.66323 1.67849 1.67849 1.69375 1.70901 1.81582 2.05997 2.31937 2.33463 2.33463 2.33463 2.33463 2.38041 2.38041 2.41093 2.41093 2.41093
1.40383 1.43435 1.43435 1.44961 1.44961 1.54116 1.75479 1.98367 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 1.99893 2.01419 2.01419
1.23598 1.25124 1.25124 1.25124 1.28176 1.34279 1.52590 1.72427 1.73953 1.73953 1.73953 1.73953 1.73953 1.77005 1.77005 1.77005 1.78531
1.06813 1.06813 1.08339 1.08339 1.08339 1.14443 1.29702 1.44961 1.49538 1.49538 1.51064 1.51064 1.51064 1.51064 1.52590 1.52590 1.52590
0.97658 0.97658 0.97658 0.97658 0.99184 1.03761 1.17494 1.32753 1.32753 1.37331 1.37331 1.37331 1.37331 1.37331 1.38857 1.38857 1.38857
0.85451 0.85451 0.85451 0.88502 0.88502 0.93080 1.05287 1.19020 1.19020 1.20546 1.20546 1.20546 1.20546 1.20546 1.20546 1.22072 1.22072
0.74769 0.74769 0.76295 0.76295 0.76295 0.82399 0.93080 1.06813 1.06813 1.06813 1.06813 1.06813 1.06813 1.06813 1.06813 1.08339 1.08339
0.62562 0.64088 0.64088 0.64088 0.67140 0.71717 0.80873 0.91554 0.91554 0.91554 0.91554 0.91554 0.91554 0.91554 0.91554 0.93080 0.93080
0.57984 0.57984 0.59510 0.59510 0.59510 0.64088 0.71717 0.80873 0.80873 0.80873 0.80873 0.80873 0.80873 0.80873 0.82399 0.82399 0.82399
0.51881 0.53407 0.53407 0.53407 0.53407 0.56458 0.64088 0.71717 0.71717 0.71717 0.71717 0.71717 0.71717 0.71717 0.71717 0.71717 0.71717
0.44251 0.47303 0.47303 0.47303 0.48829 0.51881 0.57984 0.65614 0.65614 0.65614 0.65614 0.65614 0.65614 0.65614 0.65614 0.65614 0.65614
0.36622 0.39673 0.42725 0.42725 0.42725 0.44251 0.50355 0.56458 0.56458 0.56458 0.56458 0.56458 0.56458 0.56458 0.56458 0.56458 0.56458
0.32044 0.33570 0.33570 0.33570 0.33570 0.35096 0.39673 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251 0.44251
0.27466 0.27466 0.28992 0.28992 0.28992 0.30518 0.35096 0.38148 0.38148 0.38148 0.38148 0.38148 0.38148 0.38148 0.38148 0.38148 0.38148
0.21363 0.22889 0.24414 0.24414 0.24414 0.25940 0.28992 0.32044 0.32044 0.32044 0.32044 0.32044 0.32044 0.32044 0.32044 0.32044 0.32044
0.15259 0.18311 0.18311 0.21363 0.21363 0.21363 0.24414 0.27466 0.27466 0.27466 0.27466 0.27466 0.27466 0.27466 0.27466 0.27466 0.27466
0.12207 0.15259 0.15259 0.16785 0.16785 0.16785 0.19837 0.22889 0.22889 0.22889 0.22889 0.22889 0.22889 0.22889 0.22889 0.22889 0.22889
0.07630 0.09155 0.12207 0.13733 0.13733 0.13733 0.15259 0.16785 0.16785 0.16785 0.16785 0.16785 0.16785 0.16785 0.16785 0.16785 0.16785
0.03052 0.06104 0.07630 0.07630 0.07630 0.07630 0.09155 0.10681 0.10681 0.10681 0.10681 0.10681 0.10681 0.10681 0.10681 0.10681 0.10681
0.00000 0.01526 0.03052 0.03052 0.03052 0.03052 0.04578 0.04578 0.04578 0.04578 0.04578 0.04578 0.04578 0.04578 0.04578 0.04578 0.04578
Old 07-14-2008, 08:10 PM
Haans249's Avatar
how did it work?
Old 07-14-2008, 08:39 PM
y2konyxss's Avatar
i also made these changes:
i first had to change the Min Transient Fuel to 0.032
Set Injector Flow to:
46.19404 46.50407 46.75209 47.06212 47.31014 47.62017 47.86819 48.17822 48.42624 48.73627 48.98429 49.23231 49.54234 49.79036 50.03838 50.34841 50.59643
Set Min injector pulse Width to:
0.89666 0.89666 0.89666 1.00304 1.00304 1.00304 1.00304 1.00304 1.00304 1.10942 1.20061 1.20061 1.20061 1.20061 1.00304 1.00304 1.00304 1.00304 1.00304 1.00304 1.00304
Set Default Injector pulse width to:
that got my car running better than ever before.
the SVO 42# are actually rated at 40lb/hr
once i did this change i could get the car to idle properly and the VE tuning worked great.
Old 07-14-2008, 08:51 PM
Frost's Avatar
Originally Posted by Haans249
...The only "negative" effects of running the stock voltage adjustments is SLIGHTLY rich afr's on decel, and I'm talking about 13.5-13.8 for me, and thats the extent of it.
With 60s and 42s, you can fix this in the short pulse tables for the most part.
Also keep in mind that this offset table is referenced to MAP, so if you are running manifold referenced fuel setups, all columns of this offset table must be (will be) the same.
Old 07-15-2008, 09:25 AM
Haans249's Avatar
Hey Frost, Thanks for the tip! What is the table numbers? EFILive has different table names, so I can't find the table you're referencing.
Thanks!
Adrian
Old 07-15-2008, 09:32 AM
Frost's Avatar
The short-pulse adder, default pulse, and minimum pulse tables. I'm not sure what the table numbers are
Old 07-15-2008, 10:32 AM
Haans249's Avatar
B4005, B4004, B4003.
I believe these are the tables you're talking about, but in my tune, they are not being referenced by MAP, they are being referenced by milliseconds, and rpms. At least if you're talking about the tables themselves, thats what I'm seeing, no MAP values in there.
Old 07-15-2008, 01:29 PM
Frost's Avatar
No, I said the *offset* table referenced MAP. It's just a heads up in case anyone reading is running a boost (or manifold) referenced fuel system. If so, the columns all need to be equal since the injector will now be compensated for varying manifold vacuum.
You are right about the short-pulse tables, they are in mS and RPM.
Old 07-15-2008, 01:51 PM
Haans249's Avatar
Ooook, gotcha, just mis-read your post. Thanks for the clarification.
