315s
Old 07-14-2008, 03:28 PM
FormulaZ's Avatar
Default 315s
If im putting 315s on the rear 17x10.5 rims, would I be required to have an adjustable panhard bar? Or is it optional to where I would be ok for a bit?
Old 07-14-2008, 03:42 PM
EchoMirage's Avatar
you only need the PHB if you lower your car. if not, you dont need it.
Old 07-14-2008, 03:44 PM
Mr. Luos's Avatar
While you don't need it, it isn't a bad idea.
That stamped piece isn't the sturdest.
Old 07-15-2008, 01:21 AM
Kingc8r's Avatar
^ I'm with him
Old 07-15-2008, 01:32 AM
FormulaZ's Avatar
Ok, yeah just want to make sure it holds as I will be getting the phb a week after I plan on installing the rims and tires.
I was looking into UMI and Spohn for the Adj phb, any difference?
Old 07-15-2008, 09:08 AM
'Trust''s Avatar
IMO; BMR>Sphon>UMI
Old 07-15-2008, 09:47 AM
DopdBrd's Avatar
FWIW, when I first started getting suspension parts on my old bird, I never got adjustable stuff, because I never saw a "need" for them.
On the new bird I have nothing but adjustable parts on the car, I even got rid of the non-adjustable LCA's in favor for adjustable ones.
It is soo much nicer having the ability to fine tune your suspension. I just fit some 325/50R15's with almost no modding whatsoever.
Old 07-15-2008, 10:30 AM
Silver35thZ's Avatar
about 2 and half weeks ago i got new rims and tires. got 11s out back with 315s and i lowered it the next day with eibach springs and bilstein shocks...anything bad that could possibly happen to my car if i don't replace the PHB
Old 07-15-2008, 11:01 AM
UMI Performance's Avatar
315's are usually a hit or miss when it comes to rubbing issues. If the vehicle is lowered then centering the rear end is pretty much a must to prevent tire rubbing in the fender well. I recommend an on-car adjustable set-up like the item in the link below... if you have any questions regarding the adjustment or set-up please let us know.
www.umiperformance.com/2022
Thank you!
Ryan
Old 07-15-2008, 01:27 PM
Pipelayaz's Avatar
How do you center the rear? Are instructions on how to center the rear included with the PHB?
Old 07-15-2008, 01:31 PM
99problemz's Avatar
I got mine from BMR and yes they do come with instructions, plus they have the instructions on their website as well. http://www.bmrfabrication.com/INSTALL/F-BODY_PHR.pdf
Yes or feel free to call Jerry in our technical support department as well.
Hope that helps!
Ryan
Old 07-15-2008, 09:55 PM
Pipelayaz's Avatar
Hope that helps!
Ryan
Cool thanks!
Old 07-15-2008, 10:42 PM
DUhulk78's Avatar
There was a thread not too long ago of a guy who had his lowered for about 6 months without one, and his driveshaft pretty much obliverated due to a little extra stress on the u-joint. It bent up, and hit his floorboard, and broke off i think. I havn't heard that happening a bunch, but i put one on mine, just in case...
Old 07-18-2008, 01:50 AM
FormulaZ's Avatar
Well that answers my question. Yeah hopefully get my konis and strano springs ordered within the next month or so. I will be looking into ordering the umi on the car adjustable PHB within the next 2 weeks. Thanks for the replys.
Old 07-18-2008, 08:37 AM
'Trust''s Avatar
Did that guy have an adj. tq arm? Maybe he had his pinion angle off (sounds like the problem regardless)
Old 07-18-2008, 11:09 AM
so i'm gonna need a PHB then aren't i?
can i install this myself or do i need to take it in?
Old 07-18-2008, 11:15 AM
Mr. Luos's Avatar
Pretty straight forward install.
Should be able to do it yourself no problem.
