lsx fox body guys, which radiator?
I used a large aluminum aftermarket radiator for a C5 in my 90 Mustang. It fits great. I used the factory hold down up top on both sides and was able to use the factory lower bracket and rubber grommet on the drivers side, on the passenger side the radiator had a large "dowel" rather than the flat front to back tab.... I drilled a hole in the core support large enough that the "dowel" would slide down into it. To cushion it I placed a thick piece of rubber similar to what the factory uses. It slides over the dowel and the radiator rests on it. Pretty clean and simple for anyone that has access to a Vette radiator and wants to use it.
hey mullet, my buddy has an aluminum radiator in his and he still has his stock one u think i will have any over heating issues with this and a massive s475 sittin near it?
