SLP Fan Switch
SLP Fan Switch
hey guys im going to get the SLP fan switch, but i wanted to ask some of you guys what you think quality wise, one of my friends said when he pluged it up it threw a code
need some ideas on this
billy
billy
no problems w/ mine. easy install. if you go to the track w/o a trailer and tow rig, then don't leave it on high for very long. it will drain a starting battery in no time.
i have never had a problem with mine throwing codes it works perfect. i dont leave mine on high to long because it will kill the battery fast i just run mine on hight when im in stageing and when i do my burn out and turn them off right when im geting ready to stage then after my run ill put them on high will im going back to get my ticket and to the pits.
The new version of the Aeroforce Interceptor gauge has a function that allows you to enable high and low speed fans any time you want it..
It it does just by being hooked up to the diagnostic port..
I got mine so that I could help control my tranny temps in the hot Arkansas summers. One of my coolers is mounted in front of my AC condenser, and turning the fan on high immediately drops my temps ~10 degrees. I guess it's pulling enough air through to make a difference. I didn't know if it would work, but I'm thrilled with the results. Nice piece and easy install.
The SLP switch allow you to manually turn fans on low, high (car on or off) or whatever is programmed into the PCM in the center position. Comes in handy at the track but don't use it anymore just driving around since I lovered my fan on/off temps.
oh ok I got my fans tuned to come on at like 175 when I put in my 160 thermostat car pretty much runs like 195 our here its like 100 daily so fans stay on all the time. I might get that changed
