Is this SLP LS6 intake missing something???
1 Post
i just bought this SLP LS6 intake and the guy told me its missing some type of gaskets that go between the runners where it seals to the heads, is this true? could it be for the bolt holes?? im confused, i thought the o ring gray seal was the only thing that seals it to the heads. here are some pics to show what im talkin bout, could i also grind the ribs on the bottom to fit on my coolent line?
1 Post
^^ yea sorry about the move yenko, i thought i would get some more responses here. the gaskets look fine to me, its a little weird he told me he used some stuff from this intake for another LS6 intake, i guess it was the coolent lines and foam pads?? cuz he said there was some special gaskets that go around the runners and he said thats about $50 from SLP so thats why he gave me a good deal on em
1 Post
if i could only find the online instuctions for this that would be helpfull as to what it includes, the guy said the intake has been sitting in the box in his garage for 2 years
Make sure you get some foam on the bottem of that. Pull it off your stock intake and glue it on the ls6. If you don't there's a very good chance your hear you injecters clicking and echoing though the intake. Ask me how I know.
1 Post
yea il get the foam from my old intake, umm please if anybody that has installed this can please chime in on how to do the EGR or help me find the instructions online
When I was using the egr, all you do is cut the egr tube right above the wide part from where it originally installed and sat flush on the og intake. Push it down into the compression fitting as far as it will go. Then tighten the nut. Hope that makes since where to cut it.
1 Post
